04 zx10 headache - ZX Forums
post #1 of 6 (permalink) Old 07-10-2019, 12:07 AM Thread Starter
04 zx10 headache
So I have a 04 zx10. I washed the bike and let it sit for 30 mins like I always do. Well it started just fine at first. Then it started sputtering and cut. Now it will not start back up. It is throwing almost every code related to a sensor. Can anyone shed some light on this or possibly point me in the right direction on where to start diagnosing
Pyscolilboy18 is offline
post #2 of 6 (permalink) Old 07-15-2019, 07:13 PM
Twistedsocal81's Avatar
sounds like you got the ECU connections wet. Make sure it's turned off, disconnect the negative battery lead, then unplug both of the multi pin connector bundles off of the ECU, use a can of compressed air or even a shop vac and either suck or blow all the moisture out of both the ECU and the connections. leave the seat off and aim a fan or use a hair dryer and blow on the connections on ECU and wires for a few hours with fans or about 5 or 10 min with a hair dryer. best would be to wait over night before starting it back up but that should solve the issue
Twistedsocal81 is offline
post #3 of 6 (permalink) Old 07-16-2019, 06:35 PM Thread Starter
It has been over a week. Still same issue. It throwing code 11 12 13 32
post #4 of 6 (permalink) Old 07-16-2019, 07:12 PM Thread Starter
post #5 of 6 (permalink) Old 07-19-2019, 05:46 PM
I Ride: 2007 Kawasaki ZX-14
You might want to check out a You-tube video on the valve problems the 04 to 06 zx-10 models have. The pieces of metal that hold the valve springs are too thin and they are breaking . Kawasaki corrected this with the 07 model by making the metal pieces thicker. The 04 thru 06 zx-10 models are to be avoided.
easyrider4 is offline
post #6 of 6 (permalink) Old 07-19-2019, 11:37 PM Thread Starter
I've read about that but that's not the problem with why it will not start. This is electrical for sure. I'm pretty sure I've fried the ECU.
