Front Sprocket nut!! - ZX Forums
 1Likes
  • 1 Post By metalmechanic9
post #1 of 10 (permalink) Old 06-08-2019, 08:43 AM Thread Starter
Changing out my chain and sprockets. For some reason I can not get the drive nut off the front sprocket!! Do not have a impact or anything powerful! Was wondering if there were any other way to get it off?
KawaiFamily is offline
post #2 of 10 (permalink) Old 06-08-2019, 08:44 AM Thread Starter
07 Zx10r
post #3 of 10 (permalink) Old 06-08-2019, 10:14 AM
I Ride: ZZR1100
They can be very tight. Stop now before you damage the nut.
At the very least, you need a good quality six-sided socket and a large breaker bar.
If that won't shift it, you will need an impact wrench with a matching impact socket.
I had to bring one particularly stubborn one to a local truck tyre specialist.
Ride bike there, remove sprocket cover, use huge 1" drive impact wrench
to remove 27mm nut.....
Once that was done, I tightened the sprocket nut to a more reasonable
torque, refitted the sprocket cover and rode the bike back home to change
the chain and sprockets. The nut was fairly easy to remove on the second
attempt.
ZXT10D is offline
post #4 of 10 (permalink) Old 06-08-2019, 11:48 AM
mte78's Avatar
Breaker bar and a can of MAN will get it off.
mte78 is online now
post #5 of 10 (permalink) Old 06-08-2019, 01:12 PM
Hammerhead's Avatar
I Ride: '07 ZX-14
A little judiciously-applied heat to the nut may help break it loose.
The last three I removed required an impact, one a 1" drive with 200 psi in the hose.
Hammerhead is offline
post #6 of 10 (permalink) Old 06-08-2019, 09:53 PM
olajoe808's Avatar
A breaker or an impact should get it off. did you block the wheel? In about 55k miles on Kawasaki the axles and front sprocket always use less torque then the manual never have problems later with removal or any things coming loose.
Even though you raised me I will never be your father
King of each and every Sunset Marquis
olajoe808 is offline
post #7 of 10 (permalink) Old 06-09-2019, 06:20 AM
quisp's Avatar
2 x 4 through rear wheel and someone holding rear brake .
quisp is offline
post #8 of 10 (permalink) Old 06-13-2019, 05:12 PM
The Heater's Avatar
I Ride: 3 Kawasakis
Buy a front wheel stand you can push the front wheel into. I swear by Condor front wheel stands. Leave rear wheel on pavement. You should not need a pneumatic impact wrench. Use a Propane torch to slightly heat just the nut after flattening the tabs on the lock device under the nut. Use a 1/2 inch drive torque wrench and six sided socket. It should loosen. If you use an impact wrench, set at lowest setting, do a couple short bursts. If nut does not move, increase to next setting, do a few short bursts. Just until it begins to slightly move. Impact wrenches can easily damage the shaft threads or destroy them.
1993 ZR-1100 Zephyr(modified by Zlock Racing to 1322 cc, Lindemann Engineering modified/rebuilt forks + rear shocks)
1996 ZX9R Ninja, Race Tech Susp., Ferodo Brake King Ultra Light ductile iron full floating rotors, Nissan radial brake master cyl, Galfer lines, Corbin seat, OEM exhaust.
2006 Vulcan 2000 LTD. All stock.
The Heater is offline
post #9 of 10 (permalink) Old 06-14-2019, 08:09 PM
arc
arc's Avatar
The front sprocket is exceedingly tight from the factory and requires lots of effort to undo the first time (I've had three gen 4 zx-10rs). An impact wrench and a short air hose are often necessary to get that first one undone. I know of people who have cut theirs off in desperation!
A mechanic changed out my first front sprocket on this current bike but he had to move his compressor to right next to my bike to reduce the pressure loss from the air lines in his shop. What alarmed the hell out of me though was that when I then subsequently changed the front sprocket myself, after deforming the washer, the nut was finger tight! Seriously! It undid by hand!! I had words with the mechanic and vowed to never use them again. Fast forward to the next chain/sprocket change and exactly the same thing happened: the front sprocket nut was again *finger* tight. And I know that I torqued it up to precisely the right setting with a Warren and Brown torque wrench, rear wheel held in place by a block of wood through the rear wheel and the washer properly deformed.
So, what's happening here? I'm not sure, but something to watch out for. And yes, I cleaned the thread on the bolt and inside the nut too in case of any binding.
A.
arc is offline
post #10 of 10 (permalink) Old 06-25-2019, 09:32 PM
metalmechanic9's Avatar
I Ride: 2006 ZX 14 2017 ZX-10 RR
taildragger1197 likes this.
metalmechanic9 is offline
