ZX Forums
ZX Forums (https://www.zxforums.com/forums/)
-   Tires Tires Tires! (https://www.zxforums.com/forums/tires-tires-tires/)
-   -   Maximal size (https://www.zxforums.com/forums/tires-tires-tires/205144-maximal-size.html)
Kayekidzz 11-06-2019 09:18 AM
Maximal size
Hi everybody, i'm new here. I'm a french canadian so my english is not always on point ;-)
I wanna know what is the maximal size of my rear tire for my zx7 1990
Just bought one and i wanna do many works on it. Wanna make it like a new one
Thanks you
Vic jones 11-06-2019 02:03 PM
Hi mate welcome
It seems a bit quiet on this forum
But you do get some answers some times .I think maximum is 190 /50/17 hope this helps
Zed Kable 11-06-2019 03:08 PM
170/60 rear for the ‘90 H2 et bienvenu.
Necron9d9 11-07-2019 03:04 PM
Hi and welcome man, got one myself and they're great handling bikes if you set them up right.
Yup, a 170/60 was the original rear size as Zed stated above. That was kind of a big deal back in the day that a 170 came on the bike stock.
If you do want to go wider, a 180/55 will work also but you then may want to raise the forks up in the triples to drop the front, or raise the rear ride height a bit to quicken up the steering. This is in order to make up for the change in resistance and profile of the wider rear tire.
Definitely DO NOT go to a 190 rear tire... the tire will mushroom around the rim and when you corner hard it can just "drop off the edge" of the tire without the usual warning because it is being compressed to fit on a 5.0" rear rim.
For a 190, you need to have at least a 5.5" (a la the later J/K/L/M) or ideally a 6.0 There's really no point in doing that for an H as the handling and power delivery works just fine with the original 170.
Strider 11-08-2019 12:11 AM
Hello and welcome!
Hammerhead 11-08-2019 05:29 AM
If the rear wheel is 6", you can use a 190, but pinching one down onto a narrower rim is not recommended.
Powered by: vBulletin 3.8.8
User Alert System provided by Advanced User Tagging (Pro) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
vBulletin Security provided by vBSecurity v2.2.2 (Pro) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
