1999 EX500 carb leakage - ZX Forums
post #1 of 4 (permalink) Old 02-15-2014, 04:21 PM Thread Starter
Hello, I've got a 1999 ninja 500. when i bought it the guy said the carbs were leaking. so i hooked them up and saw where they were and took action from there. I've replaced the main jets, and slow speed jets, new gasket for the float bowl. new needle valves, new oring/washer/spring and pilot screw and reset it to 2 turns out as that's what the manual said lol. put it all back together and still leaking. it's really hard to see where exactly its leaking from. i can see gas dripping off the pilot screw area, bottom of the carb itself, and the black adjusting nut in the middle of the two carbs (possibly the synchronize screw?) when i took the carbs off i never separated them and looked into the cross over tubes. so i'm left with 3 things. one, it's the over flow (no tube on it at this moment)...two. the cross over tubes are leaking. or three, the vacuum operated fuel diaphragm on the petcock isn't working right. hoping someone out there will have a little more insight and been down this road once or twice lol
tricountykustomz is offline
post #2 of 4 (permalink) Old 02-18-2014, 10:39 PM
quisp's Avatar
I assume the drain screws on the float bowls are closed? There should be o- rings at the carb end of that t- connector.
quisp is offline
post #3 of 4 (permalink) Old 02-18-2014, 10:59 PM
e1_ZX-9r's Avatar
Others use baking powder on components they want to trace leaks from. Leaks leave distinct wet runs, while leaving the remaining areas dry and untouched. Identify, rinse, repair and repeat if necessary.
Alright! Trading bikes for a while was fun.I'm ready for mine back. No, seriously, get off my bike. Ahh, what a privilege it is to have such a sweet ride.
At the track she's said to be outclassed, but on the street, she reigns unmatched. She's the only big-bore canyon carving hypermiler I know of. -- Picture gallery, K&N air filter, SuperTrapp Aluminum Racing Series exhaust (Made in USA), ZG touring shield, & otherwise stock.
Science & OODA literate. ACA covered.
e1_ZX-9r is offline
post #4 of 4 (permalink) Old 02-25-2014, 07:29 PM
Quinton Phuckin Tarantino
iron8's Avatar
I Ride: 08 zx14, 96 cbr 900rr
Garage
What I do when I have a problem like this is hook a remote fuel reservoir and test the carbs on a bench but an old gas tank will work. From your description it's probably your crossover tube that leaks, if they sit on one place for years then you turn them or put pressure on them they can easily leak.
Sir 14 Thrashin, Sometimes Peg Scrapin, Electrocutin Greasmonkey Whore of ZXF
iron8 is offline
