Battery charger blows SAE tender fuse ... - ZX Forums
post #1 of 11 (permalink) Old 01-05-2019, 04:28 PM Thread Starter
lawlist's Avatar
I Ride: 2012 ZX-14R
I would like to charge my battery on the 2012 ZX14R without removing it from the bike. I was hoping to charge the battery with the existing SAE connector that comes off the battery. So, I bought an SAE connector with alligator clips. I connected the two SAE connectors together and connected the alligator clips from the SAE connector to my battery charger alligator clips. I immediately blew the 7.5 amp fuse coming off the built in SAE connector attached to the battery. So, I went out and bought 15 amp fuses. I disconnected the charger from the electrical outlet and put in a 15 amp fuse and it blew instantly. Even though the battery charger is _not_ plugged in to a power supply, simply connecting the alligator clips from the battery to the alligator clips from the charger causes new fuses to be blown instantly. Is it possible to charge the battery (without removing it) using an SAE battery tender; and, if so, then how does one go about that?
lawlist is offline
post #2 of 11 (permalink) Old 01-05-2019, 04:55 PM
EZ Rider
185EZ's Avatar
I Ride: 2014 ZX14R
Garage
Check your polarity at the battery connector
Originally Posted by Astrav6 View Post
Ok that's an SAE connector just do a search on eBay. Not sure if the red and black are correct so ypu would need to check
December 2011 ROTM winner
YOU'RE F - KING AWESOME!!!
185EZ is offline
post #3 of 11 (permalink) Old 01-05-2019, 05:06 PM Thread Starter
lawlist's Avatar
I Ride: 2012 ZX-14R
Thank you, 185EZ, I'll check that out tomorrow. I remember being told that the red/black might be reversed, but found it hard to believe that a company makes these SAE alligator clips didn't know that black is for negative and red is for positive. Having burned out three fuses today, a wrong polarity certain seems plausible in hind-sight.
lawlist is offline
post #4 of 11 (permalink) Old 01-05-2019, 08:46 PM
Satan's Spawn's Avatar
I Ride: 05 ZX6R
If it still blows fuses, try getting a circuit breaker to put in the fuse slot until you figure it out. At least that way you can save money on the fuses.
Satan's Spawn is offline
post #5 of 11 (permalink) Old 01-06-2019, 12:47 AM
Ok don't take this the wrong way but I see it way to many times
The fuse is there to protect the system and is of the correct size so if it blows there is a problem. Replacing it with a bigger fuse will not correct the problem and in most cases will destroy what the fuse is trying to protect as it will be the next thing in the line.
If you have both sides of the Connector off the bike then if you don't have a multimeter just plug them together and slowly run your finger down the red cable from the battery side and follow it all the way to the clips and see which one it comes out on.
Dave
dave
Astrav6 is offline
post #6 of 11 (permalink) Old 01-06-2019, 03:53 AM
Hammerhead's Avatar
I Ride: '07 ZX-14
Possibly the battery has an internal short and that's why i needs charging in the first place?
Hammerhead is offline
post #7 of 11 (permalink) Old 01-06-2019, 04:31 AM
I Ride: Buell 1125r, Honda VFR800, Kawasaki ZX14, Honda CBR 600rr
No need to blow fuses or even use the battery to check this. Just do a continuity check on your SAE leads (connect one lead from multimeter to one end and the other to the other end and it will beep if there's continuity -- the female part of the plug should be +)
If you don't have a multimeter get one. It's essential equipment. Harbor Freight gives them away with any purchase and an easily found coupon. The cheap ones are fine for basic use.
You could also check battery voltage, alligator clip continuity etc. In 5 minutes you'd have it figured out methinks.
Bat-1 is offline
post #8 of 11 (permalink) Old 01-06-2019, 08:57 AM Thread Starter
lawlist's Avatar
I Ride: 2012 ZX-14R
Thank you all for the great tips. I have been wanting to buy a multi-purpose voltage tester (multimeter) and this is a great excuse to go shopping today. :)
lawlist is offline
post #9 of 11 (permalink) Old 01-12-2019, 04:28 AM
EZ Rider
185EZ's Avatar
I Ride: 2014 ZX14R
Garage
Did you figure it out?
185EZ is offline
post #10 of 11 (permalink) Old 01-12-2019, 08:50 AM Thread Starter
lawlist's Avatar
I Ride: 2012 ZX-14R
Thanks, 185EZ, for following up. Due to a combination of cold weather, rain locally and also in surrounding potential destinations within the L.A. area, general laziness, obsession with other hobbies, work related projects, time spent with the significant other, etc., the charged battery remains sitting on the corner of my desk waiting to be installed. Today is booked solid, but perhaps tomorrow I will be able to get some time in to dedicate to the Ninja ....
lawlist is offline
post #11 of 11 (permalink) Old 01-12-2019, 09:12 AM
EZ Rider
185EZ's Avatar
I Ride: 2014 ZX14R
Garage
Lol, the time it took you to write that you could have had the cables switched and charging.
185EZ is offline
Similar Threads
Installing pig-tail on battery for Battery Tender -- any tips? KemoSabe ZX-14 Forum 12 11-06-2017 05:21 AM
Battery tender/charger fail...what am I doing wrong? GNice4U ZX-14 Forum 7 12-29-2010 05:36 PM
Need help choosisng a battery charger/tender alou ZX-6R Forum 10 03-25-2009 05:25 AM
Battery Charger Connection Hitman GTR 1400 Forum 15 10-16-2007 08:06 AM
battery tender anyone? Rocklee GTR 1400 Forum 2 08-16-2007 09:15 PM
