2014 ZX14R poor idling and low speed running after valve check. - Page 2 - ZX Forums
post #21 of 30 (permalink) Old 11-30-2018, 05:43 PM
Snakes709's Avatar
I Ride: 2018 H2 SX/SE
Garage
You talking about the tabs that go under the nose fairing? I broke those to lol. I wouldnt recommend block off plates and flash unless you know for sure its that causing the problem. Have you talked to the shop that did the work?
2018 H2 SX/SE
Snakes709 is offline
post #22 of 30 (permalink) Old 11-30-2018, 05:53 PM Thread Starter
I Ride: 2014 ZX14R, 2010 VN900 Classic
Oh yeah. They have refused to take any responsibility. Oh and yeah those tabs.
sim37lewis is offline
post #23 of 30 (permalink) Old 11-30-2018, 06:34 PM Thread Starter
I know this is a stupid question but what is the trick to getting that connector off the air switch? I figured it was just push down and pull but this sucker will not budge. It does look like the hoses going to the reed valves look a bit twisted. They are old and brittle at the very least. Once I get it out I'll replace.
post #24 of 30 (permalink) Old 11-30-2018, 07:42 PM
Snakes709's Avatar
Garage
They are stubborn. You may need a set of vise grips or need nose pliers to get a good grip. Are the hoses in the correct spot on that idle speed actuator? I mixed them up the first time I put it back together.
2018 H2 SX/SE
post #25 of 30 (permalink) Old 11-30-2018, 08:15 PM Thread Starter
Thats a good question. They are off now but ill be sure to check the routing instructions. Thanks.
post #26 of 30 (permalink) Old 11-30-2018, 08:26 PM
Snakes709's Avatar
Garage
Note the hose with the dot goes on top
Click image for larger version
2018 H2 SX/SE
post #27 of 30 (permalink) Old 12-01-2018, 11:31 AM Thread Starter
Well guys. I dunno what I did right or wrong, or what's going on with the bike, but it's running sweet again. All I did was massage the air switching valve a little and make sure everything was connected securely. I put the idle actuator back on and fired it up. Idled high to warm up but dropped right into range within a few minutes. Took it off the stands and ran it around the block for twenty minutes until it was fully warmed up. No drops in power, no problems at idle. So... I dunno. I think I'm going to finish winterizing it and leave it alone until spring. If there is a problem after that I may fork out the money for someone else to handle it. Also, I guess I can live with the small oil leak from the head (sigh).
In the spring when I go to put the fairings back on will I need to get a new nose fairing (since I broke those clips) or will the other mid fairing bolts be enough to keep it from rattling?
post #28 of 30 (permalink) Old 12-01-2018, 01:03 PM
Snakes709's Avatar
Garage
Good to hear. Any issues with the fan coming on randomly or is that gone as well? As for the nose fairing, don't worry about it. Like I said, I broke both of mine and the fairings were still secured enough to not cause issues. I did multiple top speed runs and never had issues with them.
2018 H2 SX/SE
post #29 of 30 (permalink) Old 12-01-2018, 03:12 PM Thread Starter
Fan ran fine. No codes or anything. Thanks for everybodys help!
post #30 of 30 (permalink) Old 12-16-2018, 11:26 AM Thread Starter
Hi guys. Sorry if this has been asked and answered on this forum. I did a search but I couldn't find exactly what I needed. What size are those stupid push-pin type rivets? I need to order a pack to reassemble everything. Thanks!
Similar Threads
1999 ZX6R Low RPM poor running condition. codypenn56 ZX-6R Forum 2 08-24-2018 06:38 PM
ZX9R C1 poor running at low rpm Ady J Wharam ZX-9R Forum 4 11-21-2016 10:34 AM
Poor low RPM running the-b-man ZX-11 Forum 43 10-10-2014 12:32 PM
Cold start idling speed Polyman ZX-6R Forum 10 10-01-2012 06:39 PM
Low Low Speed Drop deeznutzz ZX-6R Forum 16 11-22-2007 09:59 PM
