Please help! I'm at a loss - ZX Forums
post #1 of 2 (permalink) Old 10-19-2018, 03:01 PM Thread Starter
I own a 04 636
I would be riding at higher speeds pull my clutch in and it would die no bogging or anything just die.So I'd pull over and turn it off.then it would just start right back up or did it a few times.But then I got it home I replaced the plugs and the fuel pump.So now it dosnt do that but it's hard to get it to have a decent idle.It moves up and down and if I adjust the idle screw it dosnt help any.N when I come to a complete stop it will bog so I have to hold my throttle slightly open to make it have a non moving idle.So I took my tank off to inspect my plug wires and boots.N when I unhook my fuel like from the tank it just pours fuel out.Soooo what do I do? Where should I go? What should I check? I bought a cheap 60 dollar pump off ebay is it bad and I need a OEM pump did i hook the wires up wrong? Please help.i miss riding .
Ghostrider636 is offline
post #2 of 2 (permalink) Old 01-22-2019, 01:26 PM
DanFromDNAPowersports's Avatar
fuel filter? bad pump? (I know i had issues buying a chinese vs oem pump on a zx9r) Bad ignition coil? Check spark at each cylinder. Could be a lot of things but I'd start there.
DanFromDNAPowersports is offline
Similar Threads
ZX6r A1P Cam Chain Problem - possibly screwed my bike please please please help! penroser Mechanical & Technical 2 04-29-2012 09:00 AM
Help needed please please please - cam chain issues penroser ZX-6R Forum 0 04-29-2012 03:56 AM
Streetfighter headlight wiring help. At a loss here :X kees Mechanical & Technical 3 06-17-2011 08:57 PM
please help i changed my oil filter and oil now it wont start :( please help please X.XNinjaNoobX.X Mechanical & Technical 19 12-22-2010 09:50 AM
FI light on after chargin battery. no performance loss that i can see. Help!! jetta8vwolfsburg ZX-6R Forum 0 02-22-2010 11:24 AM
