Carburetor synchronization/synchronisation - 45 minute Do-It-Yourself - Page 2 - ZX Forums
post #21 of 48 (permalink) Old 07-05-2010, 11:01 AM
I Ride: ZX-11
How can the carbs be synced with the airbox in place? I cannot reach the sync screws or nipple adapters with the airbox in place? It seems that the sync should be done with the airbox in place, cannot see how to do it?
ZX-1100
thanks
johnclark is offline
post #22 of 48 (permalink) Old 07-06-2010, 10:41 PM Thread Starter
e1_ZX-9r's Avatar
Not to worry. It's okay to take the box off if that's required for your model. By the sound of it, your ZX-11's sync screws face up at the front of your carbs. On my 2000 ZX-9r they are at the front but face backwards. On my second ZX-9r they face up and the airbox has to come off.
If I find a way to adjust them without taking the airbox off, I'll post it up. I think the airbox-on method results are more reliable, b/c my second bike is already out of sync after only 1,000 miles. Owning a tool like the CarbTune is the only way to go.
Alright! Trading bikes for a while was fun.I'm ready for mine back. No, seriously, get off my bike. Ahh, what a privilege it is to have such a sweet ride.
At the track she's said to be outclassed, but on the street, she reigns unmatched. She's the only big-bore canyon carving hypermiler I know of. -- Picture gallery, K&N air filter, SuperTrapp Aluminum Racing Series exhaust (Made in USA), ZG touring shield, & otherwise stock.
Science & OODA literate. ACA covered.
e1_ZX-9r is offline
post #23 of 48 (permalink) Old 05-21-2011, 11:03 AM Thread Starter
e1_ZX-9r's Avatar
How 'bout that!
EDIT: The quoted material may have been the result of a plugged pilot jet. I'm leaving it for historic relevance, but I am once again syncing at 1,500 RPM.
Learned something new after an extensive sync session on one of my bikes. Best results on my newer bike (using CVKD-40mm carbs) came from synchronizing the TBs at 900 RPM, not 1,500 as I've done in the past (on CVRD-40mm carbs).
And interestingly enough, the sync pointed out that my float heights are too low (lean) on this bike. F*CK. I just love this tool!!
e1_ZX-9r is offline
post #24 of 48 (permalink) Old 05-22-2011, 12:17 PM
As many carb questions pop up...this should be stickied IMO.
Why Tip-Toe Through Life Only To Arrive At Death's Door-Step Safely?
Snowblind. is offline
post #25 of 48 (permalink) Old 05-22-2011, 03:05 PM
I Ride: 2012 zx10R, 1996 zx9r
Garage
How can you tell if your floats are out of spec?
When I had my carbs apart, I used a scale to check them and they were within the specs in the manual.
jowek70 is offline
post #26 of 48 (permalink) Old 05-22-2011, 08:02 PM Thread Starter
e1_ZX-9r's Avatar
There's a difference between 'within specs' and how the height affects the low speed fuel circuit's lean/ideal/rich fuel delivery:
"If the engine is "dry" and flat between 2k to 3k rpm, raise the fuel level." Factory Pro.
If you haven't read their CV Carburetor Tuning Procedure, do it! The knowledge you'll gain from one page will be worth its weight in gold...if that could be measured.
e1_ZX-9r is offline
post #27 of 48 (permalink) Old 05-22-2011, 08:06 PM Thread Starter
e1_ZX-9r's Avatar
One obstacle even if stickied, a lot of riders don't know what a synchronization is for. But I appreciate and agree with your recommendation.
e1_ZX-9r is offline
post #28 of 48 (permalink) Old 08-27-2011, 12:20 AM Thread Starter
e1_ZX-9r's Avatar
#1 pilot jet went clogged on me!
This is what I get for letting the new bike sit for weeks on end without riding it and when I do only riding it 10 miles then parking it again. I had been noticing that < 3,000 RPM operation was getting annoying and erratic and I found out tonight why. The damn pilot jet hole for #1 was completely covered over. The ZXF advice of using a fine piece of wire did the trick. After starting it, the engine RPM was still bobbling about, so I hooked up the CarbTune to discover that clearing the jet made 1&2 off sync. Putting them back in line made the left and right bank off, so I put them back in line.
Took her for a spin. Wow, what a difference! Much much better.
All is right in the world again.
EDIT: No doubt about it, she's running fine below <3K again. Took the bike out to clear the carbon out, 273 miles worth. Feels good.
e1_ZX-9r is offline
post #29 of 48 (permalink) Old 08-31-2011, 10:05 AM
zxflyinryan's Avatar
I Ride: 86 ZX6R
i think i need to sync my carbs. i doubt its ever been done looking at what the previous owner has done to my poor machine.
zxflyinryan is offline
post #30 of 48 (permalink) Old 08-31-2011, 07:17 PM
Orion's Avatar
I Ride: 99 zx7r
Bookmarked for winter...thanx
Originally Posted by Watson 29 View Post
Ever notice that anyone going slower than you is an idiot, but anyone going faster is a maniac?
"Sir Dragon Shreddin, Ridge Runnin, Ass Munchin Whore of ZXF"
Orion is offline
post #31 of 48 (permalink) Old 08-31-2011, 08:25 PM
Bobflyer's Avatar
I Ride: 1997 ZX9R & HDNR
Just got my Carbtune from England. My home made manometer is sheet. Finally going to do it properly here.
Bobflyer is offline
post #32 of 48 (permalink) Old 09-02-2011, 05:56 PM
rnoliver's Avatar
I Ride: ZX-11 D1 Turbo, KTM 990 Adventure R
Originally Posted by unforgivenreality View Post
probably a dumb question but are the carbs on a kawi like the ones on my old honda where as num 2 carb was the base carb ie non adjustable therefore used as a base to set the rest?
By base carb, meaning it is hooked directly to the throttle cables, and all the other carbs adjust to it. In this case Yes. At least for the 11, but I'm pretty sure most banks are that way. This doesn't really make it a "master" but to change the idle positon of 2 you can only adjust the idle screw, none of the sync screws will change #2. This is why you do 1 to 2, 4 to 3 (notice when you adjust the right most screw, 4 moves, not 3) and then 3 to 2 or right pair to left pair.
But good reading and with the amount of real time that we spend in the low throttle opening range on our bikes it is essential for good operation.
“Being shot out of a cannon will always be better than being squeezed out of a tube.
That is why God made fast motorcycles, Bubba….”
My ZX 11 Mr. Turbo Build
rnoliver is offline
post #33 of 48 (permalink) Old 09-02-2011, 06:18 PM
Masta Squidge's Avatar
I Ride: '09 Concours 14, '89 RC31 and Ѡ dat ass
Thats the only thing I dont get. Dry and flat? Describe this.
The rear tire on my 14 is low on air.
So I was thinking of rebuilding the motor.
If that doesn't correct the problem, probably replace all the fairings
▬▬▬▬▬▬▬▬ஜ۩۞۩ஜ▬▬▬▬▬▬▬▬
I ride a Honda.
Masta Squidge is offline
post #34 of 48 (permalink) Old 09-02-2011, 06:31 PM
rnoliver's Avatar
That would be not-sweet and non-sparkling?
Seriously though, the difference between rich and lean (high or low fuel level) in this area can be hard to describe. Both can kind of seem like a sag in power as the engine speeds up and starts to get into the main jet circuit and run cleaner. The rich version has more of a stumble or stutter i.e. wet as in clearing your throat. The lean version is more of a flat spot in the power curve and there is no stutter or bogging cough.
I would say, for grins go screw up your floats both ways and help us describe it, but it wouldn't be worth the time.
rnoliver is offline
post #35 of 48 (permalink) Old 09-02-2011, 06:46 PM
Probably not, mine seems to be more of the rich thing, which would be only a fourth indication of it.
Floats have probably never been properly set. My bike has been abused.
I ride a Honda.
post #36 of 48 (permalink) Old 09-03-2011, 10:15 PM Thread Starter
e1_ZX-9r's Avatar
You'll definitely want to experiment with all the various settings the FP way.
As for the "dry/flat spot" concept, it is my understanding that between fuel circuits there are RPM spots where fuel delivery isn't linear. For instance, on my CVKD equipped 2002, I experimented with 14mm, where 13mm is stock: meaning 1mm leaner. I immediately noticed throttle lag, stripped the bike and put them back to 13mm.
Raising fuel height with the float will help smooth out the transition from pilot (slow) jet to jet needle.
e1_ZX-9r is offline
post #37 of 48 (permalink) Old 08-16-2012, 10:54 PM Thread Starter
e1_ZX-9r's Avatar
Adding some photos to help out
Eyeglass blade screwdriver used to adjust the pilot air screws symmetrically prior to the throttle body synchronization.
Tip #1: For the E* & F (2000 - 2003) models, Kawi recommends 1 5/8 turns on the pilot air screws, although 1 1/2 resulted in an increase in MPG, as well as, better hot starting. At 2.0 turns fuel consumption increased about 20% and mid-range throttle response turned lumpy. Both my 9Rs prefer 1 1/2 turns and easily eclipse 50 MPG except under the most extreme riding. (see Fuelly.com)
On the E1/E2 models the airbox can remain on, since the three synchronization screws face towards the back. Noted in the picture are the clear restrictor tubes, whose job it is to even out vacuum pulses.
A closer look at both the restrictor tube inserts (note #4) and the vacuum nipple locations under the intake boots (1998 - 2003, perhaps other models too).
This last photograph is not necessarily relevant to performing a carb sync, but I wanted to point out various items that some of your 9Rs may or may not have.
1) Leftmost: see the electronic connectors for the float bowl fuel cut-off solenoids.
2) Bottom center: original fuel filter, at that time with 54,000 miles on it.
3) Top Center: fuel pump
4) Right of top center: California emissions plumbing (blue/blk tubing).
5) Bottom right: California emissions charcoal canister (black rectangle).
* Pictured: 2000 ZX-9R E1 California (CA) model
e1_ZX-9r is offline
post #38 of 48 (permalink) Old 03-14-2013, 06:18 PM
Presidenté of Whoring
LeeCig's Avatar
I Ride: 2002 ZX9R
Garage
The Carbtune vacuum hoses are attached, in order, to their respective intake vacuum nipples (#92150). You remove/pop-off the existing vacuum hose, attach the Carbtune hose, sync the carbs, then reattach the existing vacuum hose to its exact intake vacuum nipple.
Picture compliments of CyclePartsNation.com
I found this thread in search, and thought, FINALLY. e1 has a zx9, I'll be able to figure out where to connect these damn hoses. Get down to this post...Oh yes, finally here it is...NO PICTURE.
Between this thread, my haynes manual, and the cycleparts break down of the 03 zx9r carbs, I still can't seem to figure out. e1, turn on your flashlight and shed some light for me please....They are CVK just for reference
Here's a new link for 03 carb parts breakdown
http://www.cyclepartsnation.com/oemp...82e/carburetor
Sir Serious Zip-Tie Lovin, Pizza Thuggin, Blue Wafflin, ZX-9 Thrashin Post Whore Of ZXF
Originally Posted by 92K1500 View Post
You win Lee.
I can't even form a response to that.
PM ME if your computer sucks!!!!!! (click here)
LeeCig is offline
post #39 of 48 (permalink) Old 03-14-2013, 06:26 PM
LeeCig's Avatar
I Ride: 2002 ZX9R
Garage
The manual says, "The take-off point for each cylinder is located at the base of the cylinder head intake port, directly beneath the carb intake rubber. Depending on model, the take-off port will have either a blanking bolt or an adapter fitting screwed into it." I found 2 bolts in the middle on the intake, and the two intake ports on the outside have hoses attached. My adapters that came with the manometer are not the same thread diameter as the bolts in the middle. I'm not sure where to go from here.
LeeCig is offline
post #40 of 48 (permalink) Old 03-14-2013, 06:58 PM
LeeCig's Avatar
I Ride: 2002 ZX9R
Garage
Re: Carburetor synchronization/synchronisation - 45 minute Do-It-Yourself
There are nipples on each of the float chambers.
You win Lee.
LeeCig is offline
Similar Threads
Carburetor synchronization dannyfumi ZX-7R Forum 1 01-21-2016 09:20 PM
smog block off... do it yourself? Vertigo117 ZX-10R Forum 15 09-12-2008 04:33 AM
What do you guys/gals do to keep yourself cool Junito General Discussion 10 07-27-2008 06:59 AM
Do it yourself SBK length akropovic' exhaust kdankenb ZX-10R Forum 4 01-09-2008 09:51 AM
1st oil change/service v.s. do it yourself? Quick6R ZX-6R Forum 11 12-17-2007 11:07 AM
