can anyone help, i am putting a zx9rb engine into my 750 frame and i am in the process of fitting the carbs, the problem i have is that i am not sure which pipes go where.
i have foundthat the bottom 2 go to the rad pipes carb preheat at a guess, there are 2 large pipes that sit between 1+2 carb and 3+4 carb, i think the top 2 are for the air intake tubes and i think the bottom 2 are for the fuel.
is this correct and if so does the fuel pipe just T off from the fuel pump via a filter. hope you understood this.
cheers stu
