Ignition Switch/Straight wire.. - ZX Forums
post #1 of 11 (permalink) Old 04-21-2011, 01:42 PM Thread Starter
ridehardorgohome's Avatar
I Ride: 1996 ZX9R B-3
Hey I need a new ignition switch.. my old one is messed up.. the table on the inside that tells what postion the key is in has a burnt bubble on the hot (white) and ground (brown).. does anyone have a replacement for a decent price.. i mean its only 130-144 depending where i wanna order it from.. but would also help if i could just replace the little wire table inside of it..
Also i was thinking to just straight wire the switch to by pass till i get my switch, whitch will make my bike that much easier to still.. but i am not worried about that so much.. I have been looking and looking, but can't find in my head to do so.. Can someone help me on to bypass my bikes Ignition Switch.. Thanks..
ridehardorgohome is offline
post #2 of 11 (permalink) Old 04-21-2011, 02:01 PM Thread Starter
Found from another post on here..
I found this from an other poster on here.. but i don't fully understand.. please help and explian..
this will sound simple, but you connect all the wires together except the grey one, connect the grey one to a 100 ohm resistor to the white wire, put the on-off switch from the rt bar in series in the white wire. (remember to conect the old wires from the rt switch together)
now the rt bar switch is the ignition and kill switch
post #3 of 11 (permalink) Old 04-21-2011, 04:28 PM
I did a google search and found many for under $50 most at $35. Id simply replace it. Pre FI wiring harness connections are close to the same on a wide variety of models. Igniton is very wide. And can sometimes still open the fuel and seat realease or be keyed to.
Just search your year and kawasaki and youll be suprised what pops up versus doing a model specific search.
tlstreak is offline
post #4 of 11 (permalink) Old 04-21-2011, 06:09 PM
Mnzx9r's Avatar
I Ride: 1994 zx9r b1
In the mean time find where the wires connect inside the switch take a piece of scrap copper wire and connect one end to the other where they go into the switch and just bypass it that way
Mnzx9r is offline
post #5 of 11 (permalink) Old 04-25-2011, 07:39 PM Thread Starter
update..
Today i went to my bike.. got me a toggle switch and a 100 ohm resistors.. got my switch on, hooked the white wire with the resistor and the gray wire to the other end of the resistor.. Put the other 3 wires together (twisted to them selfs) one would be the tail light, ground, and oil light.. got nothing going on.. so i took the other two wires.. tail light and oil light and put them to the white wire.. started turning over.. I left the ground wire out.. After 2 hours.. had to leave the bike.. i came back to the bike and started her right up.. Fues (ig,tail,head and acc) blew.. i replaced them, tired to start her again.. she started.. no problems this time, let her warm up and clean the system out. Turned her off and tried again, blew the fueses again..
My question is what am i doing wrong.. should i not have the other wires to the white wire.. should i use my harness ground wire verses wireing my own ground from the switch or what... any help would really help out a lot.. i am wanting to ride my damn bike.. lol and need to just get this one thing right and my head is running outta idea's.. Thanks
post #6 of 11 (permalink) Old 04-26-2011, 06:33 AM
I Ride: 2012 zx10R, 1996 zx9r
If i was you, instead of rigging it up and having no reliability, just replace it and be done with it.
Whatever it is, just replace it with a new one.
jowek70 is offline
post #7 of 11 (permalink) Old 04-26-2011, 08:23 AM
I Ride: A brand new 1995 Lime Green ZX9r
i think i have one if you are interested. need to look in my spares box.
Rick S. is offline
post #8 of 11 (permalink) Old 04-27-2011, 03:56 PM Thread Starter
Send me Privatemessage
If u have a good general idea or know how to truly do it send me a private message.. I think I got it but cost me my ic ignitor.. Got a new one on the way.. But need to bump heads, don't want to burn a new one up! Thanks
post #9 of 11 (permalink) Old 04-28-2011, 02:30 PM Thread Starter
I found on my manual that the white wire is battery, brown is ignition gray is ignition and the others 2 would be oil lamp n tail light.. Battery would run to main switch power.. Other wires together with resistor.. So gray with one end of the resistor (100 ohm) the other end of resistor to the brown,red/blue and tail.. Forgot the color.. Attach to the ACC of the switch and ground switch off and should be good! 96 Kawasaki zx9r b-3 for the track runners and bypasser's..
post #10 of 11 (permalink) Old 11-19-2012, 01:04 AM
were you ever able to figure this one out. I am trying to bypass my ignition but i haven't been able to crack this one. I blew my 30amp fuse once and i don't want to damage anything so if you made any head way let me know. PM me if you would
THanks
inovermyhead is offline
post #11 of 11 (permalink) Old 07-12-2013, 07:30 AM Thread Starter
yes i had bypassed my ignition.. then took the toggle switch off and bought a ignition.. go tired of going out and then having to turn around and check on my bike to make sure that it was still there.. but u can add another "Kill switch" hidden somewhere else that has to be turned on before the bike will do anything.
Human Verification
