» Insurance
McCoyMotorsportsMotorcycle.com Classifieds!ATV.com - Write Your Review and Win!
Old 09-19-2009, 08:28 AM   #1 (permalink)
carb swap
hey folk's it's another silly question will c 1'2'3 carb's fit on my b 2 or will i have to get b model carb's ive done a serch on this forum but had no look sorry if this a daft question but the only carb's i can get on ebay are mostly c and e modle one's
andywilson74 is offline   Reply With Quote
Old 09-20-2009, 09:05 AM   #2 (permalink)
e1_ZX-9r's Avatar
I Ride: 00 ZX-9r Lime Green
Size wise, they probably will. Internally very different. Dunno about whether or not their vacuum hose, fuel lines, and electronic connectors hook up too. Given how different they are internally, I'd say rebuild yours or keep looking for some used Bs.
Copied from another post I did: I'll see if I can get this right. Always assume a typo and get your own shop manual to use as the primary source of repair & specification information.
Model.........ZX-9rB..........ZX-9rC
main jet.US...#190...........#155
main jet.other#200
jet needle....staggered.....same
pilot jet......#35..............#38
pilot airscrew.(1.5 +/- 1/4)...2.0
turns
Model.........ZX-9rE..........ZX-9rF
main jet 1/4...#160...........#165
main jet.2/3...#165...........#160
jet needle....same............staggered
pilot jet......#38..............#38
pilot airscrew.(1 5/8).......(unknown)
turns
Float height for E is 4mm +/- 2mm. All others 13mm +/- 2mm.
The F model main jet stagger is correct, it's the reverse of the E. I have a spare set of these CVKD carbs and visually confirmed the sizes. Strange, I know.
Old 09-20-2009, 10:34 AM   #3 (permalink)
cheers man cant belive how much help you boy's give out will take the carb's off in a couple of day's back on shift mon tue and off till fri so will take them off and have a look think it might be because it's not been re jetted when it got the deprovic sytem put on its far to rich at the bottom end
Old 09-24-2009, 03:48 PM   #4 (permalink)
Have to ask why do you want C model carbs ?. As the B model ones are fine just make sure you dont buy restricted ones , yip they did restrict some B models through the carbs (125bhp restricted) and 135bhp unrestricted . the way to check is to see if the carb slides push up flush if they dont and stick out about 10mm then they are restricted and you will need the zxr 750 L model carb slides not the carb tops as some folk think but the slides and these will fit into your 40mm zx9 carbs .
Honestly i would stay with the b model carbs or if your brave get a set of flatsides off the zxr 750m or k model .
dendrite is offline   Reply With Quote
Old 09-24-2009, 03:53 PM   #5 (permalink)
Also its worth saying californian settings are totaly diffrent from other areas as they screw down bikes for emmissions so carb settings could be diffrent .
Old 03-09-2010, 08:57 AM   #6 (permalink)
Not to mention the carb spacing is different!
jmodified is offline   Reply With Quote
