» Insurance
BikeBanditMotorcycle.comMotorcycle.com Classifieds!
Old 09-12-2009, 05:50 PM   #1 (permalink)
I Ride: '96 ZX9R
HELP!! Bike dead. Battery Good
after riding all morning I started to go back out for an afternoon ride.
fired right up then when dead like it was just cold, but then it would not
do anything, no lights on, like the battery is dead but, it checks out fine.
Please point me in things to check from there....
ways to check starting with like the ignition switch and then on,
Thank you very much,
mjonesjr8 is offline   Reply With Quote
Old 09-12-2009, 05:56 PM   #2 (permalink)
lunaticrider's Avatar
I Ride: 09 zx6r
What did you check the battery with ? Cause i've seen it where the battery acts like it's good but under load it was shit ...
Full Akra EVO Ti (shortened pipe)
pcV with autotune
-1 front sprocket with healer
Woodcraft sliders
Hotbodies GP windscreen
Homemade fender eliminator
modified chain guard
X TRE
Zip tie mod
Factory Ohlins damper mod
Kleen air mod
Pazzo levers (green adjuster)
Spiegler brake lines
K&N air filter
And a few secret weapons
lunaticrider is offline   Reply With Quote
Old 09-12-2009, 06:06 PM   #3 (permalink)
I Ride: '96 ZX9R
Digital meter, 13+ volts, but no lights on or nothing when I turn the key,
best way to rule out the switch being bad? it's a '96 zx9r..
thanks,
Old 09-12-2009, 06:38 PM   #4 (permalink)
I Ride: 09 zx6r
Have you checked any fuses ? Checked the battery connetcions ? Grounds ?
pcV with autotune
Woodcraft sliders
X TRE
Zip tie mod
Kleen air mod
K&N air filter
Old 09-12-2009, 06:54 PM   #5 (permalink)
I Ride: '96 ZX9R
Hey, yep, checked the fuses and battery connections and grounds
thanks,
Old 09-12-2009, 07:12 PM   #6 (permalink)
I Ride: '96 ZX9R
geez, found the problem, previous owner had done a very bad job or wiring after the motor work was done, and the ignition switch connector had fallen down into the radiator fan
and got 1/2 melted and 1/2 chewed up, when I guess caused the Main fuse to blow,
which I just learned is not in the fuse box with all the other fuses... man, learn something everyday... now just have to figure out what to do about the ignition switch being so chewed up it's pretty ugly, thanks to all
Old 09-14-2009, 09:54 AM   #7 (permalink)
countriboy84's Avatar
I Ride: 01 ZX-9
Glad you got it figured out, there is a bike night on Wednesday's at Loco's off Lakeshore if you are up for it. Myself and my cousin on his 7 will be there, come on out and hang-out for a while.
01 SEMI-STOCK ZX-9 AND A NEED FOR SPEED....
Originally Posted by JBearSVT
I can empathize with your situation.
Like when somebody says "how do you know you don't like sucking dick if you've never tried it?"
countriboy84 is offline   Reply With Quote
Old 09-14-2009, 10:38 AM   #8 (permalink)
zaneyzrex's Avatar
I Ride: 2000 zrx1100
just get a new one or aftermarket replacement... EMGO etc...
zaneyzrex is online now   Reply With Quote
