Engine noise : Kawasaki ZX Forums: Kawasaki Ninja Forum
» Insurance
ATV.com - Write Your Review and Win!
Old 12-13-2008, 06:30 PM   #1 (permalink)
Engine noise
With the cold weather- how do you guys' engines sound on cold start?
My motor cranks over and starts fine, then rattles and bangs around for about 15 seconds. After the oil gets pumped around, it sounds find around 2k rpms while its warming up.
When I take the choke off, I get a really weird occasional knock coming from the upper side of the engine. It is somewhat quiet, and does not happen on every revolution. The sound becomes much more prominent if i bring the idle below 900 rpm's. Any diagnosis?
If I keep the idle at 1400 or so, it sounds fine and I don't get the occasional knock.
gharamti is offline   Reply With Quote
Old 12-14-2008, 11:50 AM   #2 (permalink)
I Ride: 2001 zx9r Kawasaki Ninja
These bikes are notorious for making noise. valves, pistons, who knows. Mine makes clicking noises but runs fine. If it rides fine, i say ride it til it doesnt ride fine. ;)
Ian_zx9r is offline   Reply With Quote
Old 12-21-2008, 02:46 PM   #3 (permalink)
Green Monster's Avatar
I Ride: '97 ZX900R Ninja
...mine makes a noise upon cold starting in the upper right side of the engine, right around the CCT area. And like you said, once the oil starts flowing, it quiets down mostly, but I don't think weather has anything to do with it...it's just as noisy in summer as in winter! lol I also changed out the CCT in 2006, just as a preventive measure.
Green Monster is offline   Reply With Quote
Old 12-22-2008, 10:04 PM   #4 (permalink)
Cool noise
wrist pin
boorod1 is offline   Reply With Quote
Old 12-23-2008, 11:25 AM   #5 (permalink)
Originally Posted by boorod1 View Post
wrist pin
thats a pretty specific diagnosis for someone that has never actually heard the bike! hah
Old 12-23-2008, 12:19 PM   #6 (permalink)
It's def the hanna canna poonah reevershram gear ring. I think there's a recall bulletin on it.
Old 12-30-2008, 10:17 PM   #7 (permalink)
Nal
Nal's Avatar
I Ride: in my dreams...
different models years have different distinctive sounds mine sounds like a honda when I put it to my friends 95 that sounds like a JD tractor on steroids, but then again if I put mine next to a honda it too sounds like a JD on steroids
Sir USAF Asian Rican, Beer Guzzlin, Road Warrior Whore of ZXF
http://s860.photobucket.com/albums/ab167/NalSS9R/
http://www.facebook.com/nalmunoz
XBOX LIVE = NALSS9R
Nal is offline   Reply With Quote
Old 01-09-2009, 11:36 AM   #8 (permalink)
hi there, my 00 zx9 also makes that noises, but when i pull the throtlle i just hear a very powerfull noise.
zx9r 00 is offline   Reply With Quote
Old 01-10-2009, 06:31 AM   #9 (permalink)
Hammerhead's Avatar
I Ride: '07 ZX-14
The older and higher mileage your engine is, the noisier it will be on two counts; 1. The most obvious thing is wear and increased clearances in mating parts. Keep those valve clearances to spec. 2. As noise standards have tightened over the years, the OEMs have made effort to quiet mechanical noise by various methods; thicker case covers, noise absorbing material added to parts and panels and engineering strategies such as cam profiles, valve train geometries and noise deadening materials on sliding surfaces such as cam chain tensioners. Change the oil regularly, do the routine maintenance and ignore the little rattles because they'll drive you nuts if you're a worrier.
Old 01-30-2009, 01:51 PM   #10 (permalink)
my old c1 model took a few seconds for the oil to reach the top of the motor but when it did it was quiet, i now run a e1 model, the oil gets round the motor much quicker but has a noiser motor at tickover, both were dam quick bikes.
mike the bike is offline   Reply With Quote
Old 01-30-2009, 02:10 PM   #11 (permalink)
Hammerhead's Avatar
I Ride: '07 ZX-14
An intermittent knock at cold idle could be stalling causing the primary gears to clank together. Nothing serious, just a lack of smooth running. Give it a little more "choke" but back it off if it zings up to 6K.
Powered by vBadvanced CMPS v3.2.2
Powered by: vBulletin 3.8.5
Ducati Forum Harley Davidson Honda 600RR Kawasaki Forum Yamaha R6
1199 Panigale Roadglide Forum Honda CBR1000 Vulcan Forum Yamaha R1
Ducati Monster Harley Forums Honda CBR250R ZX10R Forum Star Raider
Suzuki GSXR V-Rod Forums Honda Shadow Kawasaki Motorcycles Star Warrior
SV650 Forum BMW S1000RR Honda Fury Kawasaki Versys Drag Racing
Suzuki V-Strom BMW K1600 Triumph Forum Victory Forums Sportbikes
Volusia Forum BMW F800 Triumph 675 MV Agusta Forum Streetfighters
Search Engine Optimization by vBSEO 3.6.0
