BikeBanditSuperbikeToyStore.comMotorcycle.comATV.comMotorcycleToyStore5150 ConceptsAdvanstarMotorcycleShowsJazzMotorsports.com
BikeBandit
Old 07-28-2008, 08:48 AM   #1 (permalink)
increasing mpg?
hey everyone i just bought a used 2003 zx9r
i love it
has a slip-on akrapovic
dynotuned dynojet stage 1 jet kit
kn air filter/oil filter
and a few bells and whistles
well, so far i only get around 30mpg--i accelerate; but i don't really race it all the time.
so far it's been like this for every fill-up (29-31mpg, for maybe 5 tanks).
so i'm really only getting like 140miles out of a tank before i fill-up.
and i usually fill up around 120 because the guy i bought it from said he removed the reserve tank when he got the jets installed (i don't know why?)
so does anyone else with a jetkit get this kinda low mpg? it seems really low compared to what i've seen.
also, has anyone else had their reserve tank taken out? or maybe he said he integrated it with the main tank? i actually don't remember, but anyone know the reasoning behind doing something like this?
thanks for any help increasing my mpg!
eddytheflow is offline   Reply With Quote
Old 07-28-2008, 12:01 PM   #2 (permalink)
I Ride: 2003 zx-9R/2008 hayabusa
i love it
uhh removed the reserve tank???? in my 20 years of riding street bikes this is the 1st time iv heard that one. as far as your mpg/jet kit debacle you would need to take the carbs off and check them from top to bottom, kinda sounds like the float hight is to high, from the sounds of it i'd definatly get them checked out, removed the reserve tank
cott9R
cott10R is offline   Reply With Quote
Old 07-28-2008, 12:02 PM   #3 (permalink)
KEEFFIE's Avatar
I Ride: 2002 zx9
my 02 gets about the same. i have a jet kit,k@n,advancer, slip on yoshi. so i guess that would be about right.
KEEFFIE is offline   Reply With Quote
Old 07-28-2008, 12:20 PM   #4 (permalink)
Nal
Nal's Avatar
I Ride: 2001 ZX9R
maybe the petcock valve does not work, and is on reserve all the time?
Nal is offline   Reply With Quote
Old 09-09-2008, 05:34 PM   #5 (permalink)
e1_ZX-9r's Avatar
rich or way rich?
I'll leave all the 'most horsepower' stuff to those who race at Laguna Seca. My 2000 ZX-9r (see this link)has plenty of usable power and I actually had to lean the main jets for where I live, yet they're still richer than Kawasaki recommends for operation over 4,000' -- Haynes repair manual. If I were you, I'd buy some sort of repair/shop manual and check to see what the previous owner did to hose up your carbs. I wouldn't know how he removed the reserve, that doesn't make sense. Perhaps he removed the main tank's internal fuel tube so there's only 'REServe'. The tank should be a 5.0g stock tank.
The carbs on the F appear to be similar to the E, but are not identical. Your main and pilot jets appear identical to the E1. If yours is like mine, the stock main jets should be #160/165 (outer/inner cylinders). I wouldn't be surprised if you find some wild setting like #190/195 mains, pilots greater than #40 (#38 is stock) and jet needles that are shimmed up too high.
Read my link and check out how your carbs are set. Also take into consideration the altitude you're driving at. From what I've heard, the pilot air jets should be around 1 1/2 turns out (+/- 1/4), some go as far as 2 turns, but then I hear there are negative affects for going beyond that.
Factory Pro is a good source for tuning as well. I've seen many recommend it. I'd say they're more accredited than I. And there are plenty of examples online of properly tuned ZX-9s getting at least 45+ MPG. Example.
I have yet to empty the tank dry. The worst I've seen using only 91 octane, prior to carb adjustments was 175 to reserve. Now (09/06/08) it's 206 (208.1 to gas station with 3.789g into fuel usage) and probably a touch higher for highway only riding. Mind you, I'm not cruising at 140MPH or riding around town in 1st gear, like most of you are (by the sound of it), but I'm not 'representing our sport' well either.
2000 ZX-9r E1 California model, double oiled K&N, Supertrapp slip-on, altered main jets, but otherwise stock.
