zx7r - ZX Forums
post #1 of 16 (permalink) Old 06-11-2010, 07:31 PM Thread Starter
I Ride: 2002 Kawasaki Ninja zx7r
zx7r
I just got a zx7r and havent rode it very much, maybe 150 miles and today after I had been riding it for a bit it started sputtering while I was riding and shifting through the gears. Then it died at the stop light when I tried to go. Can anybody tell me what could be wrong with it? Could it be old gas making it do that? Thanks
aninjazx7r is offline
post #2 of 16 (permalink) Old 06-11-2010, 07:35 PM
2fat2fly's Avatar
Garage
Bad gas,plugged carbs,Fuel tank vent plugged,charging system took a dump.....Could be one of a number of things.Check the charging system and get a multimeter and eliminate the easy stuff first.
My Turbo ZX12R Build:
My 1993 ZX7R (M1)
2fat2fly is offline
post #3 of 16 (permalink) Old 06-11-2010, 11:28 PM Thread Starter
Ok thank you. I also forgot to mention that it would still turn over after it died but it just would not start. After I hauled it back home I let it sit for a while and was able to get it started but I am just afraid to ride it very far now. Does that narrow a few possibilities down?
post #4 of 16 (permalink) Old 06-11-2010, 11:54 PM
2fat2fly's Avatar
Garage
[QUOTE=aninjazx7r;331110]Does that narrow a few possibilities down?[/QUOTYes.Eliminate the electrical most probably.It's fuel,fuel tank vent or possibly a coil going bad when it gets hot.Ride it until it does it again.When it does,try to start it.If it doesn't start then open the fuel tank cap for a minute.Try to start it again.Does it start? If it does then it's the fuel tank vent.If it won't start until it cools completely down then it's quite probably the coil(s) going bad.This is where you'd need a multimeter to test everything when it dies to see if you're getting voltage to the coils.
My 1993 ZX7R (M1)
2fat2fly is offline
post #5 of 16 (permalink) Old 06-12-2010, 02:06 PM Thread Starter
[QUOTE=2fat2fly;331112]
Ok I will ride it and see. Just been kind of scared to ride and be stranded but i will just ride it close by. Thank you for the help.
post #6 of 16 (permalink) Old 06-12-2010, 04:23 PM Thread Starter
If it is the coil(s) what typws of coil(s) will i have to buy and replace? Sorry i'm not very familiar with all of it yet. Thanks
post #7 of 16 (permalink) Old 06-12-2010, 04:31 PM
2fat2fly's Avatar
Garage
[QUOTE=aninjazx7r;331432]
Just the stock type.You could score a set off Ebay for cheap if you're lucky.
My 1993 ZX7R (M1)
2fat2fly is offline
post #8 of 16 (permalink) Old 06-12-2010, 07:43 PM Thread Starter
[QUOTE=2fat2fly;331434]
Cool. So it would just be an ignition coil? Or are there other ones i would need to get? I'm pretty new to these engine parts.
post #9 of 16 (permalink) Old 06-12-2010, 07:54 PM
ZX7RJoe's Avatar
I Ride: 2002 ZX7R, 1994 ZX7 (Sold)
[QUOTE=aninjazx7r;331506]
You can pick them up on eBay or some motorcycle salvage yards,try these guys:
http://www.drumhillcycle.com/
I just bought a shift lever from them and I KNOW I saw ignition coil sets for reasonable prices as well.
Of course,test your first,they may not even be defective.
ZX7RJoe is offline
post #10 of 16 (permalink) Old 06-12-2010, 08:05 PM
2fat2fly's Avatar
Garage
Keep in mind that you're still narrowing down the problem.None of us are there to assist you so you're testing different things to isolate it.It's very possible that it's the coils but we don't know for sure yet.
My 1993 ZX7R (M1)
2fat2fly is offline
post #11 of 16 (permalink) Old 06-12-2010, 08:56 PM Thread Starter
Ok yea i will still test everything first but from what you were telling me it sounds like the coils because it wouldnt start until it had cooled down. So i will still have to test it first. Thank you for the website and all of the info. it has been very helpful
post #12 of 16 (permalink) Old 06-12-2010, 10:33 PM Thread Starter
Could it also be the coil if it has a hard time starting? Almost everytime i try to start it, it takes a few times before it will start.
post #13 of 16 (permalink) Old 06-12-2010, 10:42 PM
everything you've described can be brought back to dirty carbs.. start there..
ohjay is offline
post #14 of 16 (permalink) Old 06-13-2010, 02:35 PM Thread Starter
[QUOTE=2fat2fly;331523]Keep in mind that you're still narrowing down the problem.None of us are there to assist yo
post #15 of 16 (permalink) Old 06-15-2010, 10:07 PM Thread Starter
OK well I took out my air filter and cleaned it and haven't rode it since the time it died. Put it all back together and it would barely start with the choke on and then it died. I could hear it powering down and then it wouldn't even turn over like the battery is dead. The lights still come on when the key is turned. I was gonna put some seafoam in it but the damn thing wont start now. Do you have any ideas?
post #16 of 16 (permalink) Old 06-15-2010, 11:37 PM
airgreesemonkey's Avatar
I Ride: 98 zx-7r, 84 honda vf 750f
well first off welcome to the last generation of the zx7r. now there are a few tests to help break down where your problem may be. if you want to see if your getting ignition the easiest way is to remove a plug one at a time, connect it to the wire and touch the plug to the engine and try to start it, do this to every cylinder and if you can see a spark your probably in good shape ignition wise. in my experience with older bikes the most common fault is the fuel system. with your airbox pulled off spray a little bit of starting fluid in the intakes and try and start it. if it stumbles or tries to start than you most likely have a fuel issue and you will need to clean your carbs. be careful with starting fluid because too much can damage to your engine by detonation.
Sir Airplane Greasin, Curve Carvin, Badass Mofo Monkey Whore of ZXF
98 ZX7R -
84 VF 750 F - Blown Head Gasket (in repair on backburner...)
if your not living on the edge your taking up too much space
airgreesemonkey is offline
Human Verification
