Originally Posted by godswrath
there has to be someone that can answer my question
Well,there are guys on here that know better than I do but here's my 2 cents.
I've never heard of having to modify the air box after installing an aftermarket exhaust or jet kit.With a new exhaust you're moving more air through the motor than with stock exhaust,that's why you should have the jet kit,to have the ability to richen the fuel mixture now that there's more airflow.
Your lean condition could be due to carburetor settings or an air leak between your carbs and the intake (carb boots).
You can take your tank off and bungee tie it to your rear seat so that the fuel lines are still connected.Take your air box off and fire the bike up,spray carb cleaner around the base of each carb,one at a time,around the carb boot.If your rpm jump you have an air leak around the corresponding carb boot.They either need tightened or replaced (tightening it fixed mine).
If you don't have an intake leak then the lean condition is probably due to carburetor settings.Contact the manufacturer of your jet kit for recommended settings for your specific application.This should give you a good starting point.
Hope that helped.
