I think I read you can do 6 or 7 lbs of boost without changing too much, but if you go higher, you'll need to change over to lower-compression forged pistons and have the crank balanced and blueprinted. If your machine doesn't have a rev limiter (some older bikes don't) you'll want to add one since over-revving with a turbo will turn the motor into a hand grenade. Standard carburetors either have to be modified or replaced with a single, turbo-ready carb. If your motor has more than a few thousand miles on it, I would also pull the head, replace all the head bolts with higher-spec items and get the best head gasket you can buy. Undercutting all the gears and renewing all the bearings in the trans will go a long way toward keeping everything in one piece. Get some stronger clutch springs and heavy-duty plates, too. If it slips out of gear or the clutch slips under boost, that could blow it up quick.
