Depending on your setup, it should be pretty easy to do. It's not hard to figure out but you do need some decent tools and such. But first, check your pads and make sure they are the problem. You could have just hit a hard spot, or they're vibrating in the caliper, or the disc is grooved/gouged, etc. Good luck.
-Poetry written in gasoline.
