» Site Navigation |
» Motorcycle Forums
» Links |
10-18-2009, 07:34 AM
#1 (permalink)
zx7r bogging problems
ok below 5000 rpm it bogs down if i have the throttle wide open its ok, air filter good, i checked my fuel line it was kinked but still didnt help, my throttle tube doesnt stick, carbs might be a tiny bit dirty but i have kept up with them, soo
if im just cruising at 3500-5000 rpm it feels like(u know when its like your fuel is being cut off and the bike is about to die) thats hoew it feels and sounds. but if i go above 5000 rpm and start accelerating its ok. my best guess right now would be to check the fuel pump(also i live in north west florida so temp change varies form 85 one day to 46 the next but i dont think thats the underlieng problem) any help would be appreciated
it wasnt bogging when i did the wheelie lol
10-18-2009, 11:39 AM
#2 (permalink)
I Ride: 97 zx7r (p2)
gunked up carbs. are you sure the fuel filter is the correct type? i got one from autozone but found rust from the tank was getting past the filter. you float bowl gaskets might also be leaking. when i took mine apart i found the gasket was below the ridge in some places and so i took the gasket out and filed down the ridges a little so the gasket would be above the float bowl surface again. after i did all that shes been running like a champ.
i had that exact same complaint, cleaning the carbs helped at first but the prob was still there untill fixing the gaskets
10-18-2009, 01:23 PM
#3 (permalink)
well i have cleaned and put the carbs back together before and i have done that a few times and am very careful and precise. but i never hear the fuel pump so im worried thats its that, and the fuel filter is stock, the cold weather that just hit is making it worse but, its been going on for a while even before i cleaned the carbs the first time.
10-18-2009, 02:23 PM
#4 (permalink)
I Ride: '94 ZX7
Your bike requires more fuel to run at a higher rpm so if your fuel pump was bad it would get worse the more you opened the throttle.I've never heard the fuel pump on mine running either.
I've had an issue similar to yours that I've been tuning out over the last few months and it's been carburetor settings and adjustments that have helped clear it up.
10-18-2009, 02:48 PM
#5 (permalink)
well i just checked the power going to my fuel pump and its getting power, but the pump is not running i unplugged it from the power and rode it and it rides the same exzact way as it has been so now im pretty sure its the fuel pump, also the more gas u give the greater vaccum u have so higher rpm and accelerating probably helps draw the fuel but low rmp probably does not draw as much
10-18-2009, 03:40 PM
#6 (permalink)
I Ride: '94 ZX7
Wow,that's interesting,I would have thought that it wouldn't be able to run with the fuel pump disconnected.
Let us know if replacing it corrects the issue.
10-18-2009, 03:43 PM
#7 (permalink)
i will keep u guys informed
10-18-2009, 07:15 PM
#8 (permalink)
mine sure as hell wont run when disconnected...its possible when the pump is bypassed but not when its hooked up and unplugged. maybe your relay is bad too. do the test in the service manual to be certain. when i replaced my pump it burnt it up too, so on the 3rd pump i bought a used relay too and havnt had any problems
10-18-2009, 08:31 PM
#9 (permalink)
I Ride: 00 ZX-9r Lime Green
Where are your float bowl air tubes? The ones that are normally inside the RAM air duct. The symptoms you describe are typical when this device is blocked or not allowed to function as engineered.
You can search the 7r & 9r forum for float bowl tube or mod for more information.
10-18-2009, 08:41 PM
#10 (permalink)
with a clogged float vent the matter gets worse the more gas you give it, he says it gets better with more gas and above 5k
10-18-2009, 10:45 PM
#11 (permalink)
well tomorrow im doing some testing, also all of my emissions and vacum tubes are accounted for and since the last time i checked none are leaking. so i will work on it tomorrow and let u guys know
10-18-2009, 10:55 PM
#12 (permalink)
try not to walk in circles, do it right the first time and itll save you the headache...i know from experience...take notes on everything you do
10-18-2009, 10:59 PM
#13 (permalink)
everything that comes off is bagged and tagged sometimes i even get pics of how things were just to be sure. if what i think is right then with my fuel pump unplugged the bike will run like it has been, but i could be completley wrong lol we will see.
10-19-2009, 11:43 AM
#14 (permalink)
im not talking about losing nuts and bolts...i mean writing down results from tuning. more specifically the rpms that are good, ones that are bad, what gears are better than others, what temp was it outside etc....notes
these bikes can run on no fuel for a good mile or so depending how hard you ride. with my fuel tap off i can make it onto the highway before it actually starts stalling out
10-19-2009, 07:26 PM
#15 (permalink)
ok well i removed my emission system plugged what needs to be plugged rerouted what needs rerouted and it seems to run great, also i noticed on emision valve thing on top the valve cover after i removed it i nioticed that the left tube fitting coming out of it didnt have anything hooked to it just on the right side was the tube that went to the top of the carbs . so that couldnt have been good but its running good for now
10-21-2009, 08:32 AM
#16 (permalink)
hey i still have a little leak somewhere it sounds like sqeaking anyone heard this before and might know anything
10-21-2009, 10:41 AM
#17 (permalink)
area specific would be a huge plus. ive never heard a leak squeak before.
id assume youre talking about a whistling vacuum leak? it could be anywhere, grab a can of starting fluid, hold the can about 2ft away from the airbox and do a small spray mist near each carb base...if you can HEAR a vacuum leak its bad and itll suck that starting fluid up fast and the engine rpms are gonna jump
10-21-2009, 04:34 PM
#18 (permalink)
yeah im gonna check the tubes tomorrow, but i was finially able to fill it up with gas and ride it today, and it is super responsive, and the front wheel seems to come up easier. im very glad i took the emissions off
