ZX9r engine into ZX7r?? - ZX Forums
 1Likes
post #1 of 29 (permalink) Old 05-24-2009, 07:29 AM Thread Starter
Case's Avatar
I Ride: Mille R
Sorry if this has been asked about a million times but here goes! Big fan of the ZXR750 and ZX7R, but has anyone here dropped the ZX9R engine into the ZX7R frame? I've been told its pretty easy and I've been thinking about one as a project.Has anyone got any experiance/opinions or info on this?
Case is offline
post #2 of 29 (permalink) Old 05-24-2009, 12:11 PM
2fat2fly's Avatar
Garage
Here's where you need to look:
http://www.webzxr.co.uk/
Click on tuned ZXR's on the left sidebar.
Then scroll down to:
750/900 Conversion Guide for '91 to '95 ZXR750s
It will have all your answers and a step by step guide to getting it done.
2fat2fly is online now
post #3 of 29 (permalink) Old 05-25-2009, 03:11 AM Thread Starter
Case's Avatar
I Ride: Mille R
Just what I was looking for,thanx mate
Case is offline
post #4 of 29 (permalink) Old 05-25-2009, 11:29 AM
2fat2fly's Avatar
Garage
Anytime.
post #5 of 29 (permalink) Old 05-27-2009, 09:50 PM
I Ride: 1999 ZX7R
Required Parts for ZX7 to ZX9 Engine Conversion
1. 1994-1997 ("B" Series) ZX9 Engine (899cc)
-Same width, higher top height.
-Don't even think about a newer 9R engine, they're a completely diffrerent block, and ARE too wide for the ZX7R frame...period.
2. ZX9R CDI Module (Ignition Module)
-Maps the ignition advance and retains the lower ZX9 Redline Limiter
3. ZX7 to ZX9 Engine Conversion Mounting Kit (BRG Racing)
-Relocates Engine Mounts
-Relocates Oil Cooler
-Relocates Radiator Mount
Optional Parts
1. ZX9R Carbs
-Larger Diameter
-More top end power
2. BRG Air Cleaner Adapter Kit
-Moves the airbox up higher to keep it from burning/melting
3. ZLOCK Racing Big Bore Kit & Machine Work
-2MM Overbore (Increases Displacement to 950cc)
*Absolutely the largest bore you can go*
-Performance Pistons
-Performance Piston Rings
-New Wrist Pins
-New Clips
-New Gaskets
*Patented Zlock Racing head lock design called "Lid-Lock"
-All Machining Included
-All Instructions Included
-------Optional-------
-Cylinder Head Port work
Cost: Expect around $2,000 for the ZLOCK Racing Big Bore and head work, and somewhere in the range of 140+ HP
Resources
http://www.brgracing.com/zx7-9.html
http://www.zlockracing.com/index.html
-Click Tuned ZXR's on the left side, and it will direct you to various sites with information on the ZX7 - 9 engine swap.
99' ZX7R
*Puig Double Bubble Windscreen*Jetted Carbs*Fiberglass Race Fairings*Full Muzzy Stainless Steel Exhaust*Carbon Fiber Mirrors*LED Tail Light*K&N Air Filter*Flo-Commander*Eliminated stock undertail*Grab Handle Delete*KLEEN Mod*Slipper Clutch Mod*Fresh Paint*
villian88 is offline
post #6 of 29 (permalink) Old 05-28-2009, 08:27 PM Thread Starter
Case's Avatar
I Ride: Mille R
Awesome,thanks for the info
Case is offline
post #7 of 29 (permalink) Old 06-08-2009, 12:17 AM
Can a '93 zx7r be used.
hamiltonfighter is offline
post #8 of 29 (permalink) Old 06-08-2009, 03:31 AM Thread Starter
Case's Avatar
I Ride: Mille R
Absolutely, have a look at the link above,it covers 91 to 95 model ZX7R's
Case is offline
post #9 of 29 (permalink) Old 06-12-2009, 08:34 AM
Hi there from scotland
See some of you are wanting to do the conversion on the zxr750L , ok well i have done it and its easy if you have a good pair of hands , i also see someone has a list that would scare the shite out of you , but all you need is a dremel and a 13mm drill yip thats all.
First mount the zx9B engine in the top rear mounting just put the bolt in no need to tighten it up , now raise the front to see where the oil pipe on the side of the zx9 engine strikes the top mount now mark this and grind away till you raise the engine again bearing in mind the top engine mount on the frame and engine mount wont line up you get them as near as possable and run a 13mm drill through the top mount into the off set engine . EASY
Emmission crap , on top of the rocker cover blank these of wither it be with mr muzzys blank off plates or simply block the rubber pipes off , then junk the emmission crap on the right hand side the thing with all the hoses comeing out , keep the hoses you will need them for the next bit .
Next bit drill a hole in the front lower part of the air box ,so its below the air filter make sure the hole is slightly smaller than the bigger hose off the emmission crap as its this you will be fitting into it and joining up with pipe that comes out of the top of the carbs , now you have done this you have done what kawasaki couldnt and that is equal pressure between the carbs and airbox which allows you to drop back the stupid large jets which makes the throttle response better .
Carbs , ok not a lot of people no this but they restricted some zx9`s throught the carbs , restricted 125bhp unrestricted 135bhp . How do you check this ,well simple push the slides up and they should rise fully up (flush) if they dont and they stick out about 5to 10mm then its restricted , if they are just take the slides out of your zxr750 carbs and place them in note when taking out the restricted 9 slides the big plastic top on them not the carb tops as many think . Also bear in mind this when buying off ebay if you dont have a set of zxr carbs .
CDI what ever you do , do not be tempted to run the 750 cdi use the 9 as you will blow it up , yip i did .
ZX7 is basicaly similar but you will need a new oil feed top mountin bracket again muzzy do them .
All i can say is once its done go out hunting down the so called high performance bikes as this machine when sorted will pass new blades and r1 on twisty roads as it has the best front end and now it has the power that kawasaki should have done in the first place . honestly you wont stop laughing . if any of you get classic motorcycle mechanics the march or april edition look at the owners bikes as mine is in it .
dendrite is offline
post #10 of 29 (permalink) Old 03-13-2010, 06:28 PM
aki_tycoon's Avatar
zx9B engine into zxr750 H/89 frame...
hello guys....
will zx9B engine fit into zx7 89 frame???...
anybody tell me???
aki_tycoon is offline
post #11 of 29 (permalink) Old 03-14-2010, 07:00 AM
90ZX7's Avatar
I Ride: 1990 zx7 1992 zx7r 2000 zx9(current bike) 2001 gsxr 619 1981 kz1000
theres a 91 zx7 with zx9 swap all professionally done for 3000 in my area of toronto, can its nice looking bike black with polished everything
90ZX7 is offline
post #12 of 29 (permalink) Old 03-14-2010, 07:12 PM
I Ride: 92 zx7r, and 91 zx7
Actually I just found out that pistons & barrels from a zzr will fit and takes it to 980cc.
Got info from another zx7r forum.
I've got a 92 zx7r K model with the zx9r motor swap.
I've collected and waited 3 years,.. now doing the 950cc big bore, lighten balanced crank, reprofiled cams, Ti retainers and heavy duty valve springs, flat faced valves, airtech ram air, upgraded suspension all around full racetech upfront, gold valve and springs for my weight. Keihin 39mm FCR's, sudco needles, last but not least, marchesini forged mag 5 spoke rims. 520 chain and sprocket conversion. full set of fiberglass fairings including a custom fiberglass tank.
Will get motor back in approx, 4 weeks. Then dyno'd hopeing for approx. 155-160 Hp
at wheel.
I've used those site and been a member on the red monkey forum for about 7 years now.
Love the zx7r's
cheers
Paul
cheers
knotty1 is offline
post #13 of 29 (permalink) Old 03-14-2010, 09:35 PM
aki_tycoon's Avatar
so...y'll mean that the 9b enjin will fitted into 7h frame???is it???
post #14 of 29 (permalink) Old 03-15-2010, 12:08 PM
BigBoyZX7R's Avatar
I Ride: 04 ZX10R
ZX9R B engine from 94 - 97 fits fine
BigBoyZX7R is offline
post #15 of 29 (permalink) Old 03-16-2010, 06:57 AM
aki_tycoon's Avatar
HAHAHAHA....are sure????!!!
i'm gonna get that engine right now....
post #16 of 29 (permalink) Old 03-17-2010, 04:41 AM
The 9b engine does not fit zxr H models!!!!!
spuddy25 is offline
post #17 of 29 (permalink) Old 03-17-2010, 10:36 PM
93kawizx7's Avatar
I Ride: ZX6R 636
Is that price of $2000 including the zx9 motor?
93kawizx7 is offline
post #18 of 29 (permalink) Old 04-03-2010, 06:29 AM
aki_tycoon's Avatar
u'r right...it will fit...but,too many things to mode....frame,lower mounting...
i am working on it,when it done....i'll show it...
LUX-ury likes this.
post #19 of 29 (permalink) Old 04-05-2010, 09:42 AM
I Ride: '00 ZX7/9R, '84 GPZ900R
Hi ya,
Just putting the finishing touches to my engine swap, can't wait to hit the Sussex roads.
One problem I've got is throttle cables. The cables (both 7 and 9) are too short to go through the original route to the carbs. However, if I put them through the hole in the frame on the right hand side the curve from the throttle housing to the hole is too tight and the cables are REALLY stiff with no free movement. Help please ?
Oh, if any of the good 7 riders in the UK have a good spare rad they would be willing to part company with for a reasonable price I'm in the market please. Mine is ...... um.........tired, oh and full of mud from the front wheel.
Many thanx
Big Bird is offline
post #20 of 29 (permalink) Old 04-22-2010, 07:28 AM
aki_tycoon's Avatar
guys...look at this...
zx9 B3 engine in a zx7 H frame...hehehehehe......
it work!!!!!!!need many of modyfication....
Human Verification
