Originally Posted by GreenT
So it's getting extra fuel right?? Is the throttle stuck on?? Choke spring or slider is stuck on as well?? Bad Carbs>???
If the engine when revved Accelerates uncontrollably It means a Lean Condition.
Usually due to Low float bowl levels or Clogged idle jets.
Basically the engine is running a lean Air to Fuel Ratio. Leaner=Hotter.
Also runs the risk of damaging the internals of the engine.
This is ten percent luck, twenty percent skill
Fifteen percent concentrated power of will
Five percent pleasure, fifty percent pain
And a hundred percent reason to remember the name!
To resist is to piss in the wind
Anyone who does will end up smelling
Knowing this, why do I defy?
