Originally Posted by TwiztedZX7
I did try to cap the overflow tube and gas started coming out of the fuel cap, when I started the bike. The last couple days I put gas in the bike I have only been able to go about 100miles before switching over to the reserve. When refueling I have been putting a lil over 2 gallons thats as much as it will go before coming out the overflow tube.
Josh
If your only putting 2 gallons in the tank your full. (It's a 5gal. tank 4 gal main 1 gal reserve) and 100 miles is about 3 gal worth of fuel.
Anyway make sure your seals on the cap are good and that you have them all. There should be 2 under the cap, 1 on the cap it self and the other on the tank that covers the inside where the cap sits.
