Vertical headlight adjustments are on the back of the headlight assembly on the top outside of where the bulb is located. Horizontal adjusters are located on the lower inside section. Is kinda hard to explain, there is a link in the ZX7 section where you can download the service manual in PDF, it has pics of the headlight assembly showing exactly where they are located. Be sure you are on the bike in full gear when you adjust for the best results. Will keep you from having to do it twice.
