Anything is possible. but keep in mind that 04-05 fairings are cheaper than the 06-07 fairing. With that being said, the shape of the front fairing is also alittle different based on the yr. If this is not a concern, than use either one you can afford.
I would rather get front zx10 clip and mate it to the zx7r fairing. all fiberglass. this way the mian fairing will be inplace and mating the two will be simplified. The zx10 fairings are too jagged for that zx7r sweeping tank.
the zx636 subframe can be modified to fit the zx7r with minimal effort and will match the zx10 fairing. Just a thought.
Good Luck.
Just know one thing, if you think you will do this mod for UNDER $1000.00. You are wrong. Not trying to rain on your parade, just letting you know that once you start something like this the headaches will pop up.
The head light mod alone will cost $350-500.00! that's for the customizing and maynot include the fiberglassing.
Personally I think it was a nice attempt but end result is kinda weak. Nice in some respects but not something that I would present to the world. Def. a work in progress.
-Frank
