Racer Parts WholesaleMotorcycle.comCheapCycleParts.comAdvanstarMotorcycleShowsMotorcycle.com Classifieds!5150 ConceptsSuperbikeToyStore.comMotorcycleToyStore
JazzMotorsports.com
Old 07-22-2008, 04:10 PM   #1 (permalink)
1Fast7's Avatar
I Ride: zx7 '92
Any engine builders?
I need to know the location of the crank shat when it is TDC.
1Fast7 is offline   Reply With Quote
Old 07-23-2008, 08:26 PM   #2 (permalink)
timing plate is on the right hand side of the motor.
ninja11zx is offline   Reply With Quote
Old 07-24-2008, 12:52 PM   #3 (permalink)
1Fast7's Avatar
I Ride: zx7 '92
I need to know what angle/degree the crankshaft is at when cylinder 1 is top dead center. The kawasaki manual dose not say it only give specs and run outs.
Old 07-24-2008, 03:35 PM   #4 (permalink)
#1 and #4 rod journals are straight up. timing plate will line up 1 and 4 position with a mark on the cases.
Old 07-24-2008, 07:52 PM   #5 (permalink)
1Fast7's Avatar
I Ride: zx7 '92
What i'm looking for is in example when cylinder 1 is top dead center the crankshaft is at 120 degrees. I know where the marks line up i need the angle/degree of it. What i have to do is make a new ignition wheel with 24 teeth evenly spaced then grind one of so that i have a skipped tooth. I need this to program the ecu for the fuel injection that i have done.
Old 07-26-2008, 10:28 PM   #6 (permalink)
I Ride: 97 zx7r (p2)
niiiiiice idea dude, what fi system are you piecing together? sorry i dont have an answer, but im really curious how its gonna turn out.
Old 07-27-2008, 04:03 PM   #7 (permalink)
1Fast7's Avatar
I Ride: zx7 '92
The throttle bodies are from a 636 the bore spacing is the same so they don't need respacing. You also have to use the manifolds from zx6/636 also.
