MotorcycleToyStore5150 ConceptsJazzMotorsports.comAdvanstarMotorcycleShowsBikeBanditMotorcycle.comRacer Parts WholesaleATV.com
JazzMotorsports.com
Old 07-22-2008, 07:12 AM   #1 (permalink)
Jvela's Avatar
I Ride: 1994 Zx7
How do i wire the fan to run all the time...93zx7
i have a 93zx7, which seems to get hot very quicker then normal, how do i bypass or wire up the fan to run the whole time i have the bike running?? any help would be appreciated
thanks
Jvela is offline   Reply With Quote
Old 07-22-2008, 09:39 AM   #2 (permalink)
hotdemongel's Avatar
I Ride: green 07 kawasaki zx10r
hey jvela, as i put in your other thread about this...".i cant help you with that, but why do you need the fan on constantly? the bikes not running hot is it? if so the fan on constant is a poor and quick diagnosis/fix respectively. its designed to cut in at a certain temp to maintain it. hows it going to get to running temp. when its cold? and if you put a manual switch on it, your sure to forget at some point in time and poss. overheat the engine...not being negative, just curious." you didnt say it runs hot. knowing that, have you checked the coolant level, radiator condition, thermostat, hose condition? maybe you need to pull the rad. etc. off and inspect a few things (being an older bike)or take it to a mech. got a manual? if not ask someone here who can pass on a pdf manual your way.or search for it on the net, theres a few sites out there that will let you download for free. youre not fixing it by wiring the fan on.
"please dont make me angry.................you wouldnt like me when im angry!" ?
http://i266.photobucket.com/albums/i...l/DSC02282.jpg
hotdemongel is offline   Reply With Quote
Old 07-23-2008, 09:24 AM   #3 (permalink)
dirty13south's Avatar
I Ride: 2005 ZX10R
You need a volt tester and find the hot wire to your ignition with the key ON make sure it's only hot when the keys on. Run a wire from there to the fan the the other wire from the fan to a ground on the engine.
OR you could wire it to a toggle switch on the positive side just cut the wire and put the switch in. This way you could hook it up straight to the battery.
