Motorcycle.comATV.comMcCoyMotorsportsHot Bodies RacingMotorcycleToyStoreD2MotoFullThrottleMotorsports
Please Visit our Site Sponsors
Old 05-06-2008, 01:39 PM   #1 (permalink)
is this normal? running hot?
I am wondering if my bikes temp gauge is correct, the gauge sits about 1/4 way up on normal riding and same when riden a bit harder (i'm new lol)
The frame is actually quite hot to touch after riding, i noticed as i thought my legs were feeling quite hot so felt the frame and its alarmingly warm! fan works ok and gauge appears to be ok.
Also looking at the rad etc i noticed there is a small pipe about half way up the right hand side of the rad is a pipe outlet which has a blank rubber pipe over it and jubilee clipped up, is that right? shouldn't it go somewhere?
thanks in advance
mike
mike hayward is offline   Reply With Quote
Old 05-06-2008, 02:42 PM   #2 (permalink)
Chief's Avatar
This is common for these bikes. The plastics have insullation on the inside of them to reduce heat and chance of melting. What this does is it forces the heat towards your body and the frame.
As for where the temp gauge is running at, that is normal. Once the temp gets to a certain temp the sensor turns on your fan.
If you are uncomfortable with the heat you could always remove the cowlings and run your bike naked to reduce the heat.
Hope this helps you out.
Chief is offline   Reply With Quote
Old 05-06-2008, 02:43 PM   #3 (permalink)
Chief's Avatar
Oh also that hose on the side is normal too. This is your over flow tube.
Old 05-08-2008, 10:35 AM   #4 (permalink)
thanks for your help people
Heres the pipe i am on about
i dont think that is an overflow of any sort thou.
mike
Old 05-08-2008, 04:59 PM   #5 (permalink)
KawieKrazy's Avatar
I Ride: 07 ZX10R
its normal, the motor will get over 200 while idling, never noticed the frame being super hot to the touch, although I try not to touch hot motorcycle engines or exhausts, tends to hurt.
KawieKrazy is offline   Reply With Quote
Old 05-08-2008, 07:48 PM   #6 (permalink)
ChrisB's Avatar
I Ride: 97 ZX7R
there should be a hose connected there. it runs to whatever the part is thats mounted on the right side of the oil filter. sorry Its dark and I cant tell what it is. theres also another hose coming from the thermostat housing going to that same part.
"Sure, nine out of ten people would want a Harley if you asked them, but then again, nine of ten people don't know shit about bikes."
-JGullato
ChrisB is offline   Reply With Quote
Old 05-09-2008, 12:52 AM   #7 (permalink)
missing hose?
I think that hose go's to the oil cooler which is located to the right of the oil filter when sitting on the bike. If you remove the right side faring and the bottom cowl you can get a better look at it. Get yourself a shop manual or go to bikebandit.com. Terry
godfather is offline   Reply With Quote
Old 05-09-2008, 11:22 AM   #8 (permalink)
That's correct. The radiator port connects to the lower port of the oil cooler via a long rubber hose. Obviously the port on the oil cooler is also plugged. Not sure why this would be done, but as you've seen from the replies on Redmonkey, you are not alone in having that line capped.
Bozo is offline   Reply With Quote
