Having lot of trouble installing this slip on Yoshimura : Kawasaki ZX Forums: Kawasaki Ninja Forum
» Insurance
Motorcycle.com Classifieds!
Old 02-21-2012, 06:39 PM   #1 (permalink)
I bought the bike with a straight pipe on it because the last owner was an idiot.
I just bought a Yoshimura RS-5 slip on and I thought I put it on correctly last night, then today when I was at the DMV I saw that the pipe was completely disconnected and loosened from what I thought was a tight fit.
Can you give me advice how to properly install this? I tightening the clamp a lot and it worked for a second, then the pipe came out, and I even bent the metal from tightening so hard.
I must be doing something wrong.
xrjon0609 is offline   Reply With Quote
Old 02-21-2012, 06:43 PM   #2 (permalink)
Masta Squidge's Avatar
I Ride: Pain meds and Ѡ dat ass
You may need some kind of shim. I need to shim my Muzzy - and it is the one that came with the header.
The rear tire on my 14 is low on air.
So I was thinking of rebuilding the motor.
If that doesn't correct the problem, probably replace all the fairings
▬▬▬▬▬▬▬▬ஜ۩۞۩ஜ▬▬▬▬▬▬▬▬
DAMN THIS SIGNATURE IS FANCY!
Masta Squidge is offline   Reply With Quote
Old 02-21-2012, 06:46 PM   #3 (permalink)
iand's Avatar
I Ride: ZX6R
you may have overtightened it. bending the metal from tightening can reduce the friction needed for proper fitment.
Sir Spankin New Sixxxer, Breakfast Makin Triple Word Lovin Whore of ZXF
10-27-2010
09 ZX-6R
Muzzy Slip On
Originally Posted by whitehendrix View Post
drunk
iand is offline   Reply With Quote
Old 02-21-2012, 06:46 PM   #4 (permalink)
Shit forgot to post picture, here it is.
And I'm not sure, that little metal mesh thing he has was tightened around the straight pipe.
Old 02-21-2012, 06:54 PM   #5 (permalink)
Oh fuck, is the female male thing wrong. Don't know how to word it. But was the Yoshimura pipe supposed to slip OVER the pipe, or inside of it.
Old 02-21-2012, 07:17 PM   #6 (permalink)
e1_ZX-9r's Avatar
Hard to tell on the angle, but it looks like the flow is right to left. The mid-pipe's outlet diameter is matched to the slip-on's inlet diameter, whatever diameter that turns out to be. It sounds like you figured it out on your own. It definitely looks reversed and that, by definition, would be incorrect. An exhaust pipe's outlet diameter must either be static from beginning to outlet or increase as it makes its way to the outlet. Diameter restrictions can bottleneck exhaust gas flow.
A pic from the exhaust muffler how-to I did a couple years back
Alright! Trading bikes for a while was fun.I'm ready for mine back. No, seriously, get off my bike. Ahh, what a sweet ride. ...Your eyes do not deceive. She can travel about twice the distance of your bike without stopping. Challenges welcome, but no whining about having to chase her for 5 - 7 hours. -- Picture gallery, K&N air filter, SuperTrapp Aluminum Racing Series exhaust (Made in USA), Zero Gravity touring shield, stock gearing & ignition.
ROTM Apr-2010 & Sept-2012
Old 02-21-2012, 07:25 PM   #7 (permalink)
The left pipe is the Yoshi, and the right side is stock downpipe. Are you saying the Yoshi should fit AROUND the stock downpipe?
Old 02-21-2012, 07:33 PM   #8 (permalink)
iand's Avatar
I Ride: ZX6R
i don't think its going to fit around the down pipe. might have to get some of that mesh stuff between the two
10-27-2010
09 ZX-6R
Muzzy Slip On
drunk
Old 02-21-2012, 07:41 PM   #9 (permalink)
clarkmanning's Avatar
I Ride: '08 ZX10r
I think you need the proper sleeve, (looks like it's made of some type of lead/graphite material), between the oem pipe and the new slip-on. I ran into a similar issue with an LOR slipon on a 10R. Just didn't look right or fit right. when I reinstalled the sleeve taken from the oem pipe, everything slipped together perfectly.
clarkmanning is offline   Reply With Quote
Old 02-21-2012, 07:42 PM   #10 (permalink)
e1_ZX-9r's Avatar
I'd only be repeating.
Old 02-21-2012, 07:44 PM   #11 (permalink)
iand's Avatar
I Ride: ZX6R
thank you
10-27-2010
09 ZX-6R
Muzzy Slip On
drunk
Old 02-21-2012, 10:07 PM   #12 (permalink)
The mesh wont fit right, it's all frayed and gets clogged and stuck. I should probably just go to home depot and find something.
So just for clarification, I SHOULD be using that mesh filler?
If so, what kind should I buy?
Old 02-22-2012, 08:39 AM   #13 (permalink)
08zxripper's Avatar
I Ride: 08 zx6r vivid yellow
i believe the "mesh thing" is basically a gasket, so to speak, to you dont have any exhaust leaks. forgot to put mine in the first time too, then i had to take everything apart and reinstall. but im almsot 100% the mesh peice is your problem
2008 ZX6R : Yoshi RS-5 slip on, Jumper mod, BikeLitez FE, Blue led accent lighting throughout, Pro-grip tank protector,12000k HID kit, -1+2 sprockets, RK Gold 520 chain
yet to come: Round bar, SI cage, cut fairing, Handbrake
08zxripper is offline   Reply With Quote
Old 02-22-2012, 11:05 AM   #14 (permalink)
What should I buy to fill the gap and make it gripped tight, and where would I go to buy it?
Old 02-22-2012, 02:28 PM   #15 (permalink)
tscheck's Avatar
I Ride: 2009 ZX6R Monster
The alternative to using a gasket would be to take it to a muffler shop and have them use an exhaust pipe expander on the end. Similar to:
tscheck is offline   Reply With Quote
Old 02-22-2012, 05:43 PM   #16 (permalink)
Just went to an auto parts store, nothing. Went to home depot, nothing. What to do?
Old 02-23-2012, 12:54 AM   #17 (permalink)
soc_monki's Avatar
I Ride: 2008 ZX-6r
dealership to get the correct gasket :)
2008 ZX-6r : Yoshi RS-5 full exhaust, 5150 rearset risers, Pinebox taillight, removed reflectors, relocated license plate, jumper mod, K&N air filter, PC III, -1/+2, chinese shorty levers
soc_monki is offline   Reply With Quote
Powered by vBadvanced CMPS v3.2.2
Powered by: vBulletin 3.8.5
Ducati Forum Harley Davidson Honda 600RR Kawasaki Forum Yamaha R6
1199 Panigale Roadglide Forum Honda CBR1000 Vulcan Forum Yamaha R1
Ducati Monster Harley Forums Honda CBR250R ZX10R Forum Star Raider
Suzuki GSXR V-Rod Forums Honda Shadow Kawasaki Motorcycles Star Warrior
SV650 Forum BMW S1000RR Honda Fury Kawasaki Versys Drag Racing
Suzuki V-Strom BMW K1600 Triumph Forum Victory Forums Sportbikes
Volusia Forum BMW F800 Triumph 675 MV Agusta Forum Streetfighters
Search Engine Optimization by vBSEO 3.6.0
