Bike Wont Start In First Gear : Kawasaki ZX Forums: Kawasaki Ninja Forum
» Insurance
Motorcycle.com Classifieds!
Old 06-26-2010, 06:33 PM   #1 (permalink)
Yeah pretty much what the title states. It use to start in gear but now it doesnt. Anyone know why?
JayRSXS is offline   Reply With Quote
Old 06-26-2010, 06:37 PM   #2 (permalink)
I Ride: '07 zx10
neutral safety switch
team ftp
1000cc's
because you can ride a 10 slow
but you can't make a 6 fast
uzimon is offline   Reply With Quote
Old 06-26-2010, 06:52 PM   #3 (permalink)
Say what? Oo well my friend has the exact same bike and his starts in gear with the kickstand up.
Old 06-26-2010, 06:57 PM   #4 (permalink)
ADMINISTRATOR
185EZ's Avatar
I Ride: '07 ZX14 '05 Honda VTX 1300 2008 ZX6R
your kickstand switch is out of adjustment or bad
Originally Posted by wess
Man you are awesome! Thanks
185EZ is offline   Reply With Quote
Old 06-26-2010, 08:17 PM   #5 (permalink)
Crack's Avatar
I Ride: 2007 zx6r, 2008 zx10r
adjust u clutch cable..may be to tight and the clutch is not engaging and disengaging fully.
zx6r-Full Akrapovic, Kleen Air mod, Jumper mod, Sato rearsets, ASV shorties, Puig DB, passenger delete, Power Pures, Woodcraft framesliders, Driven grips, -1/+2 Driven Sprockets, DID ERV3, Xtre, PCV, Spiegler SS lines, BMC air filter, GP shift, speedohealer, rear brake reservoir relocated...
zx10r-Yoshimura r-77 Slip-on, Pazzo Levers, Attack Rearsets, Speigler SS lines, Puig DB, GP shift, Shogun Sliders.
More to come for both animals.
Crack is offline   Reply With Quote
Old 06-26-2010, 10:39 PM   #6 (permalink)
Its definitely not a bad sensor because if i do have the stand down and i go from neutral to first itll shut off
Ill give that a try
Old 06-27-2010, 01:05 AM   #7 (permalink)
MrBubbles00482's Avatar
I Ride: 93' ZX6e
Will it start in any other gear?
Neutral safety on mine will start any gear with clutch in only, and clutch out only in neutral. Kickstand doesn't have anything to do with starting, only engaging into gear...
Check all electrical connections for sure, if one function of the sensor stops working then I would think the other would also seeing as its on a common plug..does the bike like to idle down a lot when stopping or doesn't it seem to have drag while in gear with the clutch in..like your having to hold it back?
If so then you need to adjust the clutch cable properly till it engaged and disengages all the way.
Ride- 1993 ZX6e
Vance and Hines full exhaust
Factory pro stage 1 kit (much better then dynojet IMO)
Uni filter
Cali emissions to 49 state conversion
Air Blade DB dark smoke
Spike bolt kit
Full 2002 GSXR 1000 subframe/rear end
Lowered 1.25" in front
2004 GSXR mirrors
Smoked lights/signals
2003 ZX6 Adjustable preload forks
98-99 zx6r swingarm/back half
6" stretch
14/44 gearing
Turbo in the works...
MrBubbles00482 is offline   Reply With Quote
Old 06-29-2010, 05:07 AM   #8 (permalink)
ADMINISTRATOR
185EZ's Avatar
Say what? Try starting in gear with the kickstand down.
Old 06-29-2010, 06:57 AM   #9 (permalink)
I Ride: 93' ZX6e
My kickstand switch could possibly be different, it would start with the stand down in gear, or go into gear with the stand down, but when starting to release the clutch any at all it would die.
Ride- 1993 ZX6e
Uni filter
Spike bolt kit
2004 GSXR mirrors
6" stretch
14/44 gearing
Old 06-29-2010, 07:00 AM   #10 (permalink)
ZXXXXXXR's Avatar
This is a key sign that it is messed up and f.g.a.s. Give it a good fixin' and you'll be good to go!
Sir Thread Jackin, High Pressure Sales Whore of ZXF!
ZXXXXXXR is offline   Reply With Quote
Old 06-29-2010, 07:29 AM   #11 (permalink)
rileydeed's Avatar
I Ride: 2008 CBR1000RR, 2000 ZX9r sold
If it wont start in gear with the clutch pulled, the problem is probably the switch on the clutch lever. On mine I was able to carefully disassemble the switch and clean the contacts and it works fine now. If you try this be careful as there are some tiny little springs in there. Of course you could just buy a new one. If you clean it be sure to lube it up with some good electric grease. The contacts are all kinda exposed to the elements so some grease is a good idea.
Sir Flower Child, Welcome Wagon Howdy Whore of ZXF
I much prefer being on 2 wheels, more maneuverable and quicker than the pack so I can snake through the stupid. --Shifty1
rileydeed is offline   Reply With Quote
Old 06-29-2010, 12:22 PM   #12 (permalink)
I Ride: 2007 ZX6R
I have a friend that had the same issue with an 07 ZX6R. I noticed that he had aftermarket levers. The levers were set so close to the grip that the switch was not being triggered. He adjusted the lever and it was fine. So, it could be your clutch cable adjustment.
Bridge-Engineer is offline   Reply With Quote
Old 06-29-2010, 12:34 PM   #13 (permalink)
netstat's Avatar
I Ride: '01 ZX6R
Mine won't start in gear, I just thought that's how it was supposed to be. I'll have to check lever adjustment when I get home.
Flat Black 2001 ZX6R (with Cali emissions )
* 15/45 Supersprox setup
* Custom shorty Yoshimura RS-3
Originally Posted by Rocketman14 View Post
If a bird in the hand, is worth two in the bush, then a hand in the bush, is worth dinner and a movie!
netstat is offline   Reply With Quote
Old 06-29-2010, 04:30 PM   #14 (permalink)
zippy's Avatar
there is a switch in your clutch that goes out often in many bikes.
Why is it evertime I use my sliders, I smell gas?
zippy is offline   Reply With Quote
Old 06-29-2010, 04:57 PM   #15 (permalink)
Forum Leader
rrzxter's Avatar
I Ride: fat chicks
Hope you get the problem fixed.
Just a question though, whyTF are you guys concerned with being able to start the bike in gear anyway? Why not put it in neutral? Do you guys sit on your bike, holding the clutch in, waiting for the oil to circulate and warm up?
I must've missed the post that explained why starting the bike in gear and sitting there with the clutch in, made sense.
<img src=http://i647.photobucket.com/albums/uu199/rrzxter/you_like_this_facebook_thumbs_up_bumper_sticker-p128127724679874290z74sk_400.jpg border=0 alt= />
Sent from my laptop using the recliner app.
rrzxter is offline   Reply With Quote
Old 06-29-2010, 07:12 PM   #16 (permalink)
netstat's Avatar
I Ride: '01 ZX6R
i wasn't actually worried about it, but it would come in handy if my dumb ass stalls it :)
Old 07-02-2010, 07:41 AM   #17 (permalink)
Yep. I mean i get lazy sometimes and ill stall it on accident so i would like it in a situation like that. Having to brake put your foot down put it in neutral then start is kinda dangerous.
Powered by vBadvanced CMPS v3.2.2
Powered by: vBulletin 3.8.5
Ducati Forum Harley Davidson Honda 600RR Kawasaki Forum Yamaha R6
1199 Panigale Roadglide Forum Honda CBR1000 Vulcan Forum Yamaha R1
Ducati Monster Harley Forums Honda CBR250R ZX10R Forum Star Raider
Suzuki GSXR V-Rod Forums Honda Shadow Kawasaki Motorcycles Star Warrior
SV650 Forum BMW S1000RR Honda Fury Kawasaki Versys Drag Racing
Suzuki V-Strom BMW K1600 Triumph Forum Victory Forums Sportbikes
Volusia Forum BMW F800 Triumph 675 MV Agusta Forum Streetfighters
Search Engine Optimization by vBSEO 3.6.0
