Is my clutch going bad??? : Kawasaki ZX Forums: Kawasaki Ninja Forum
» Insurance
ATV.com - Write Your Review and Win!
Old 04-19-2010, 07:39 PM   #1 (permalink)
So the title pretty much says it all, is my clutch going bad? It only seems to screw up on me in first gear or first is where its most noticeable. If i take the bike to about 8k or 9k and give it a fair amount of gas the rpms go up like they should but the speed doesnt or at least not like it does in the first 8k of the rpm range. I figured this is probably my clutch beginning to go out on me. Any input from you guys would be great. thanks
ltdrider is offline   Reply With Quote
Old 04-19-2010, 11:14 PM   #2 (permalink)
ALBERT55's Avatar
I Ride: 2009 ZX6R(now). 2005 ZX6R-636(2nd bike) 2003 ZX6R-636(1st Bike)
what kind of bike? How many miles? Give us a bit more info
The best thing I ever did was get a bike
ALBERT55 is offline   Reply With Quote
Old 04-20-2010, 07:01 AM   #3 (permalink)
Administrator
Shifty1's Avatar
I Ride: 2005 ZX6R
If your clutch cable is properly adjusted then I would say, yes, your clutch is slipping and it's time to replace it.
-Poetry written in gasoline.
Old 04-20-2010, 07:49 AM   #4 (permalink)
ecochranezx6r's Avatar
I Ride: 2000 ZX6r
I have a 2000 zx6r and am experiencing the exact same thing in first. I'm also fairly noobish...is there a way to adjust the clutch cable yourself? any tips?
ecochranezx6r is offline   Reply With Quote
Old 04-20-2010, 07:56 PM   #5 (permalink)
my clutch went out last year at nashville speedway, i could tell it was going out because of the same symptoms, except mine was going out at 13000 rpms. according to the speedo, i was only running 135 when i should of been 155 or more. also try from dead stop in third gear, you will tell if it slips.
9388 is offline   Reply With Quote
Old 04-21-2010, 09:17 AM   #6 (permalink)
Its a 2001 its beginning to slip in other gears now too, so i have just assumed its the clutch. You can tell when it really should be pickin up the speed the speedo will stay semi still while my rpms go as they should. i found an ebc clutch kit on ebay so i think im going to try that and see what happens. Hope replacing the plates arent too much of a pain in the rear.
Old 04-21-2010, 08:33 PM   #7 (permalink)
replace the steels also, and let the clutch fibers soak in oil for a few hours before you put them in. if its a zx-6r you should get on americasmotorsports.com and look up the parts fiche for your bike, it'll show a pic of the clutch. you'll see two rings or clutch washers, mine were tapered and not flat, make sure you put those in the way you take them out. my book never said they went in a certain way. but i know they do.
Powered by vBadvanced CMPS v3.2.2
Powered by: vBulletin 3.8.5
Honda Grom Forum Harley Davidson Honda 600RR Kawasaki Forum Yamaha R6
1199 Panigale Roadglide Forum Honda CBR1000 Vulcan Forum Yamaha R1
Ducati Monster Harley Forums Honda CBR250R ZX10R Forum Star Raider
Suzuki GSXR V-Rod Forums Honda Shadow Kawasaki Motorcycles Star Warrior
SV650 Forum BMW S1000RR Honda Fury Kawasaki Versys Drag Racing
Suzuki V-Strom BMW K1600 Triumph Forum Victory Forums Sportbikes
Volusia Forum BMW F800 Triumph 675 MV Agusta Forum Streetfighters
Search Engine Optimization by vBSEO 3.6.0
