93' ZX6 build. GSXR rear end swap. : Kawasaki ZX Forums: Kawasaki Ninja Forum
» Insurance
Old 02-02-2010, 08:47 PM   #1 (permalink)
MrBubbles00482's Avatar
I Ride: 93' ZX6e
93zx6e,GSXR tail, turbo, zx6r swingarm
Name changed, gsxr subframe swap is finished. Please jump to page 7 for start of turbo and zx6r swingarm swap with extension.
Original bike
After fixing and paint.
4 broken body panels, not cracked, missing chunks
Full exhaust, no jetting
Front tire with a bubble in it
Shot chain and sprockets
Sitting at 11,xxx miles
And now, tear down. GSXR swap drops more then 30 pounds rough estimate. 15 or 20 just in the subframe.
2002 GSXR 1000 subframe
02' plastics, solo cowl, and seat.
Integrated tail light
OEM undertail
Air blade double bubble screen
Full spike bolt kit (fairing and windscreen)
Green SS front brake lines (back tire likes too locks enough already)
Soon...
Valve adjustment
Tires (Michelin PP2CT, running stinko's right now... )
Pics
Took the rear end plastics and stuff apart earlier this afternoon.
Front end off
Parts table
Fender before
Fender design
Fender after
Did this a while ago. My belly pan was melted from the exhaust, so I cut it, layed about 15 or 20 2x8 squares of 1.5oz matt, soaked them individually and bam, cross bracket. Trimmed it tonight.
Close up
Got her naked on the rear end =]
Along with some sanding to get new paint on.
GSXR parts will be here tomorrow afternoon.
Then the top came off =]
Cleaned up and painted to match the anodized bars.
Base
Full rear end (minus undertail)
Frame off.
Frame on.
Mock up.
Tail
Electrical nightmare when i hooked the battery up backwards...lol
Melted the plug...
Radiator relocate and tail light wiring
Front lights had rash so I DA'd it out
VHT nightshade down, clear soon
Triple mounted after paint
One last check
Back down to move for paint (Tomorrow or Thursday)
Ride- 1993 ZX6e
Vance and Hines full exhaust
Factory pro stage 1 kit (much better then dynojet IMO)
Uni filter
Cali emissions to 49 state conversion
Air Blade DB dark smoke
Spike bolt kit
Full 2002 GSXR 1000 subframe/rear end
Lowered 1.25" in front
2004 GSXR mirrors
Smoked lights/signals
2003 ZX6 Adjustable preload forks
98-99 zx6r swingarm/back half
6" stretch
14/44 gearing
Turbo in the works...
MrBubbles00482 is offline   Reply With Quote
Old 02-03-2010, 03:34 AM   #2 (permalink)
tuscanidream's Avatar
I Ride: zx6r36
Looks sweet! I would clean up and strengthen where the subframe not bolts on. Makes me nervous. Maybe weld a square at the end of the old subframe and the new weld two outer tabs to slip over the old subframe?
Edit: I see that you cut and notched it.? I'd toss a plate on the backside where you cut it away weld the two together. Just my opinion.
Does the seat align with the fuel tank? Or is that just a wierd photo?
I aint going to the morgue cuz fear is on my side. But I rot my brain out with thoughts of one wheeled suicides. On a permanent field trip every time I get on and ride. My road rash feels like it just got hit with hydrogen peroxide.
tuscanidream is offline   Reply With Quote
Old 02-03-2010, 04:29 AM   #3 (permalink)
JBearSVT's Avatar
I Ride: 2005 10R
I never thought I'd like seeing the ass end of a gixxer, but I suppose if it's still Kawi powered it's acceptable
I'm really enjoying this build, it's looking great!
ΜOΛΩΝ ΛΑΒΕ!
JBearSVT is offline   Reply With Quote
Old 02-03-2010, 08:26 AM   #4 (permalink)
I Ride: 93' ZX6e
Those photos were before I moved it up closer to the tank, now there is about a 1/2~ gap between tank and seat, but i'll be doing something about that later, you'll see
The reason for bolting..I don't know how to weld, and don't know anyone that does...lol.
I figured, notching the new sub frame inside the old one would be strongest by bolting...I've been thinking about running another through the top to bottom. Bolts are grade 8, 1.5"x5'16's. Any bigger and I think it would take away to much metal. Also running one more through each mounting point from top to bottom, might comprehend strength my taking away to much metal at the mounting point.
Ride- 1993 ZX6e
Uni filter
Spike bolt kit
2004 GSXR mirrors
6" stretch
14/44 gearing
Old 02-03-2010, 08:53 AM   #5 (permalink)
TreyE's Avatar
Looks like its gunna be pretty sweet, lookin forward to seeing it done.
Tits.
TreyE is offline   Reply With Quote
Old 02-03-2010, 05:51 PM   #6 (permalink)
Moscap87's Avatar
I Ride: 06 ZX600J6 (ZZR600)
looks good. definitely interesting. only suggestion: powdercoat frame parts, not paint. otherwise good job so far
Moscap87 is offline   Reply With Quote
Old 02-03-2010, 09:18 PM   #7 (permalink)
I Ride: 93' ZX6e
I would, powder coating would be a lot better, but I don't have the time/money for it.
I got all the plastics back down to primer, they need wet sanding and then they will be ready for paint.
Ride- 1993 ZX6e
Uni filter
Spike bolt kit
2004 GSXR mirrors
6" stretch
14/44 gearing
Old 02-03-2010, 09:33 PM   #8 (permalink)
Smalls's Avatar
I Ride: 2003 ZX-6R
Subscribed!
Keep posting pics please :-)
Smalls is offline   Reply With Quote
Old 02-03-2010, 10:19 PM   #9 (permalink)
I Ride: 93' ZX6e
Originally Posted by Smalls View Post
Subscribed!
Not to worry, I will as progress comes.
Watching a set of 03 ZZR600 forks on ebay right now, my left one has a hairline crack in the lower leg.
Ride- 1993 ZX6e
Uni filter
Spike bolt kit
2004 GSXR mirrors
6" stretch
14/44 gearing
Old 02-04-2010, 07:17 PM   #10 (permalink)
I Ride: 93' ZX6e
Just won a set of 2003 ZX6e (zzr600) 41mm forks for 48$. Straight and seals are still good.
Now I have adjustable pre load.
Ride- 1993 ZX6e
Uni filter
Spike bolt kit
2004 GSXR mirrors
6" stretch
14/44 gearing
Old 02-06-2010, 09:43 PM   #11 (permalink)
I Ride: 93' ZX6e
Green Cyclops anyone?
So I saw the guy that did the home made halo's on his 6.
I'm waiting on it to warm up, and LED's and resistors are cheap, so I figured ah what the hell.
MY bike only has one headlight housing and bulb, so it will be a cyclops, a green one at that.
Got everything out.
Baked the housing. 4 minutes at 250 split it right open (with the help of a screw driver.
Working on the reflective cuts.
Ride- 1993 ZX6e
Uni filter
Spike bolt kit
2004 GSXR mirrors
6" stretch
14/44 gearing
Old 02-07-2010, 07:16 AM   #12 (permalink)
I Ride: zx6r36
Sweet. Should toss a projector while you are in there :)
Old 02-07-2010, 08:54 AM   #13 (permalink)
zaneyzrex's Avatar
I Ride: 2000 zrx1100
Thumbs down
to each their own i guess..
but i would be checking to make sure someone didnt put a huge amp main fuse/or jump it with aluminum foil in your starter relay... shouldnt have melted the plug before blowing the fuse.....
Old 02-07-2010, 01:50 PM   #14 (permalink)
I Ride: 93' ZX6e
The plug had burn markes from before this problem just not as bad. The white wire which is the ignition wire had a break right after the plug.
The fuse problem was me. Upon the subframe swap, the battery had to be flipped around because the posts were hitting the mounting bolts for the new subframe. So I swapped the battery, and not the terminals...battery was wired backwards...mistake on my part.
Ride- 1993 ZX6e
Uni filter
Spike bolt kit
2004 GSXR mirrors
6" stretch
14/44 gearing
Old 02-10-2010, 11:08 PM   #15 (permalink)
I Ride: 93' ZX6e
Damn tax bullshit...
03 forks will be here tomorrow
Upper fairing stay from a 97, straight and true 9.95$
Will be here next week.
There is a show coming up I wanted to get the bike ready for, BUT my parents are screwing me out of my tax return. If they claim me as a dependent (which they are) they get a $3,600 tax credit (which is good I understand that) but it makes me OWE 208$. If they DON'T claim me, then I would be getting 585$ back.
The thing is, they are claiming me, and paying my 208$ I'll owe....but that's it...I don't get anything else, which is pretty shitty in my eyes..as they say, "It's the lesser of two evils" even though they are pretty much telling me I'm fucked...and it's their fault.
I would be satisfied if they gave me the 377$ difference from the 208$ I'll owe..but sadly no they won't even discuss it.
Ride- 1993 ZX6e
Uni filter
Spike bolt kit
2004 GSXR mirrors
6" stretch
14/44 gearing
Old 02-11-2010, 04:01 AM   #16 (permalink)
JBearSVT's Avatar
I Ride: 2005 10R
Apparently, you are younger than I had assumed.
Feel free to take that as a compliment.
ΜOΛΩΝ ΛΑΒΕ!
Old 02-11-2010, 12:10 PM   #17 (permalink)
I Ride: 07 zx6r
cool i guess. but i think your pissing money away, and i dont think id ride it, not sure how safe it would be at speed. Good luck, but i think u shoulda left it stock, and just rode it and saved up for a newer bike.
AjZx6r is offline   Reply With Quote
Old 02-11-2010, 12:13 PM   #18 (permalink)
JBearSVT's Avatar
I Ride: 2005 10R
I think maybe you're missing the point of this sort of project.
ΜOΛΩΝ ΛΑΒΕ!
Old 02-11-2010, 03:06 PM   #19 (permalink)
I Ride: 07 zx6r
Please enlighten me? im more worried for his safety
Old 02-11-2010, 03:45 PM   #20 (permalink)
I Ride: 93' ZX6e
What are you conserned about being safe at speed?
The new subframe?
Repaired plastics?
Front forks?
All the plastics are solid, I've been fiberglassing since I was 15, and I know how to get it to work with plastics. They are solid and trustworthy.
The subframe is full grade 8 hardware, and most subframes are bolt on now a days anyway. Granted the mounting points for factory bolt on subframes are stronger, but it's locked in good. I suspended the bike from ratchet straps to remove the swingarm for some cleaning, no bends, no giving or stress. All is in shape.
The forks are getting fully replaced with 2003's from the same bike. Good seals, no cracks. I've already inspected them. The font suspension is no problem anymore.
JBearSVT
How old did you think I was?
19 right now if you were wondering.
I'll be ordering transmission parts next week to repair second gear.
Should only need 2nd, 6th, and the output forks..if that. 6th seems to function fine, but I'll find out once I pull the motor this weekend, hopefully the drum is fine, but where it engages 2nd it might be worn.
New forks
Also.
Any concerns should be addressed more specifically. I don't understand why you are "worried about my safety". The bike was fully checked over before purchase. Brakes, frame (even the 2 re-welded spots), rims, and forks (crack was spotted). Everything that is known, is being addressed.
This bike will be one off. No other like it. MY own creation with a decent platform to build on.
Ride- 1993 ZX6e
Uni filter
Spike bolt kit
2004 GSXR mirrors
6" stretch
14/44 gearing
Powered by vBadvanced CMPS v3.2.2
Powered by: vBulletin 3.8.5
Ducati Forum Harley Davidson Honda 600RR Kawasaki Forum Yamaha R6
1199 Panigale Roadglide Forum Honda CBR1000 Vulcan Forum Yamaha R1
Ducati Monster Harley Forums Honda CBR250R ZX10R Forum Star Raider
Suzuki GSXR V-Rod Forums Honda Shadow Kawasaki Motorcycles Star Warrior
SV650 Forum BMW S1000RR Honda Fury Kawasaki Versys Drag Racing
Suzuki V-Strom BMW K1600 Triumph Forum Victory Forums Sportbikes
Volusia Forum BMW F800 Triumph 675 MV Agusta Forum Streetfighters
Search Engine Optimization by vBSEO 3.6.0
