Key won't open gas cap... - ZX Forums
post #1 of 37 (permalink) Old 12-23-2009, 11:27 AM Thread Starter
rroger25's Avatar
I Ride: '08 zx-6r
Went to put gas in my bike and the key won't turn the lock on the gas cap to open it.. wtf?
Any ideas?
rroger25 is offline
post #2 of 37 (permalink) Old 12-23-2009, 11:30 AM
la_kawi's Avatar
I Ride: '05 ZZR600
Maybe some WD-40 in the key hole.
...just another (last of the single color) Kawi cruisin' SoCal.
BikePics
Meetup
Facebook
MODS:
Galfer front & rear Wave Rotors, Spiegler SS Lines, Vortex + 1 PTFE Hardcoated Sprocket, Driven front Sprocket, RK XW-Ring 520 Chain, Two Brother M2, Factory Pro Ignition Advancer, shimmed needles, K&N Filter, Gilles Tooling rearsets, ASV Levers, Watsen Design flush mount signals, Driven D3 Grips, 6000K HIDs, Targa hugger, Mototek undertail,
MICHELIN PILOT POWER 2CT Tires
la_kawi is offline
post #3 of 37 (permalink) Old 12-23-2009, 11:30 AM Thread Starter
rroger25's Avatar
I Ride: '08 zx-6r
Tried that and let it sit for days. Still no dice.
rroger25 is offline
post #4 of 37 (permalink) Old 12-23-2009, 11:43 AM
Maximus96792's Avatar
I Ride: 2008 ZX6R Special Ed.
Smile Key
Push Down on the forward most part of the Cap as You turn the Key.
Common Issue, not covered under warranty. I would use Graphite not WD40.
Maximus96792 is offline
post #5 of 37 (permalink) Old 12-23-2009, 11:47 AM
Shifty1's Avatar
I Ride: 2005 ZX6R
I would try a penetrating lubricant and see how that works.
-Poetry written in gasoline.
Shifty1 is offline
post #6 of 37 (permalink) Old 12-23-2009, 12:13 PM
08_bluezx6r's Avatar
I Ride: 08 plasma blue zx6r
use super glue works the best lol jk that sucks i would be pissed
08 plasma blue zx6r-relocated brake reservoir-homemade fender eliminator-black and silver seats-destrickerd
08_bluezx6r is offline
post #7 of 37 (permalink) Old 12-23-2009, 12:13 PM Thread Starter
rroger25's Avatar
I Ride: '08 zx-6r
Tried that too lol. It's like the lock was rekeyed...
rroger25 is offline
post #8 of 37 (permalink) Old 12-23-2009, 12:26 PM
-Op-'s Avatar
I Ride: '05 ZX6R
does the key turn it at all? or can you just put the key in and thats all
2k5 Plasma Blue 636
Mods:
-1 Front Sprocket.
FE Kit, with a touch of DIY
K&N Air Filter - Installed
EBC Gold Sintered HH Front Brakes - Breaking-in
-Op- is offline
post #9 of 37 (permalink) Old 12-23-2009, 12:44 PM Thread Starter
rroger25's Avatar
I Ride: '08 zx-6r
Doesn't turn. Just put the key in.
rroger25 is offline
post #10 of 37 (permalink) Old 12-23-2009, 12:48 PM
Hammerhead's Avatar
I Ride: '07 ZX-14
Drill the lock cylinder and replace the cap with a screw-on unit. I am just waiting for mine to screw up to do the same thing. A locking gas cap is the stupidest thing ever put on a motorcycle.
Hammerhead is offline
post #11 of 37 (permalink) Old 12-23-2009, 01:30 PM
la_kawi's Avatar
I Ride: '05 ZZR600
I actually got rid of my locking gas cap this past October.
...but to Hammerhead's point, you may be limited in options and may need to go the route he suggested. Have you tried calling a local Kawi service center and see what they suggest?
BikePics
Meetup
Facebook
MODS:
la_kawi is offline
post #12 of 37 (permalink) Old 12-23-2009, 01:59 PM
bdruggan10R's Avatar
I Ride: 2007 ZX10R S.E.
As la-Kawi said, the only option may be to get an after market gas cap. Had to replace mine after it seized. If you want to know what yours is doing, then take a look. You have a bloom of Galvanic corrosion.
I ended up having to replace mine with a Roaring Toyz set after trying several times to save the stock one. Once it starts, it can not be saved.
Officer Doughnut Suckin, Hooker Bustin, Knee Scrapin Legal Eagle of ZXF
Roaring Toyz Fuel Cap, Spiegler SS Braided Red Front Brake Line Kit, Galfer SS Braided Red Rear Brake Line Kit, Targa Fender Eliminator Kit, Brake Light Modulator, Modified Puig DB Painted Opaque Black Windscreen, Spiegler LSL Frame Sliders, Custom Billited Swingarm Spools, K&N Air Filter, Two Brothers Juice Box, Solo Seat Cowl, Yana Shiki Brake and Clutch Levers, HR1 Pocket Exhaust.
bdruggan10R is offline
post #13 of 37 (permalink) Old 12-23-2009, 03:20 PM
judas's Avatar
I Ride: 2007 ZX-6R
take it to a lock smith theyll get it working
Michael Thompson II
judas is offline
post #14 of 37 (permalink) Old 12-23-2009, 04:31 PM
They may get it working, but due to the corrosion, it will fail again.
post #15 of 37 (permalink) Old 12-23-2009, 04:38 PM
I was wandering why you guys are having so many problems with corrosion, particularly in the gas cap. In 25 years Iíve never had any problem with that.
I will never again post in this forum!!!
Rodster is offline
post #16 of 37 (permalink) Old 12-23-2009, 04:53 PM
Originally Posted by Rodsct View Post
I was wandering why you guys are having so many problems with corrosion, particularly in the gas cap. In 25 years I’ve never had any problem with that.
The key lock mechanism itself is a soft metal, inside the key cover tab is another metal, such as aluminum, (not sure) The two metals touch when the key cover is closed and causes the galvanic corrosion.
post #17 of 37 (permalink) Old 12-24-2009, 11:32 AM Thread Starter
rroger25's Avatar
I Ride: '08 zx-6r
I noticed that white sh*t in the same area on mine before I tried the wd40. However, there wasn't as much as in your picture.
rroger25 is offline
post #18 of 37 (permalink) Old 12-24-2009, 02:20 PM
Well! Bump on the head for Kawasaki for not foreseeing that!
Rodster is offline
post #19 of 37 (permalink) Old 12-24-2009, 02:34 PM
houltmac's Avatar
I Ride: 2016 ZX-6R
Garage
I have the same thing from time to time. I tend to let it sit and cool for a minute and all is well. Occasionally it gets stuck for a good 10 minutes of trying and I twist the key. I turn it the other way to bend it back or it won't fit in the ignition (yes I know it's all bad, but I have a temper with inanimate objects when I need to go some place)
Matt
2016 ZX-6R 30th Anniversary
Akrapovic slip-on, ASV Shorty Levers, Radiator Grille, Bobbins, Micro LED Indicators, R&G Tail Tidy, Silver Indicator Bulbs
houltmac is offline
post #20 of 37 (permalink) Old 12-24-2009, 02:40 PM
HIrideZX10R's Avatar
I Ride: 09 R6, 09 ZX10R
You can always try getting an aftermarket gas cap ^^^^ ....it'll make life a lot easier.. I had a little problem with mine the first time I try to open it up but after that it's been fine.
HIrideZX10R is offline
Human Verification
