» Insurance
OPP RacingATV.com - Write Your Review and Win!BikeBanditSportbikeTrackGear
Allstate
Motorcycle.com
Motorcycle.com Classifieds!
Old 11-06-2009, 07:52 PM   #1 (permalink)
ZX6Ray's Avatar
I Ride: 08 ZX6R
Exclamation Warning to those with HID's
So I'm at the dyno shop to get my bike re-tuned after I installed the MJS performance header (great quality BTW) and my bike is running lean and misfiring throughout the powerband. So with no tune and 2 hours later I'm in the garage with the bike apart testing the resistances and voltage outputs of this that and the other thing using the service manual. Come to find out I tested the resistance on the stator and luck behold no readings indicating an open circuit. I'm not sure about how long stators are supposed to last but the only thing that I'm running on the bike that's not stock is the HID's. That along with the starter turning the engine and the various other loads on startup probably damaged the stator over time.
So I have to ask if anyone on here has had similar problems with HID's and the bike's electrical system in general?
I bought the HID kit from Fsane Performance and I'm thinking about completely running without them or I could wire a switch in there and only turn them on when I'm riding the bike. What do you guys think?
Throttle up, knee down and pray.
ZX6Ray is offline   Reply With Quote
Old 11-07-2009, 04:55 AM   #2 (permalink)
JBearSVT's Avatar
I Ride: 2005 10R
Huh. They're supposed to draw less current than the stock light, so that wouldn't make any sense, but I've never really looked into exactly how they work so...
-Jess
How could they predict the end of the world and miss seeing the Spanish coming?"
-JKL1960
ΜOΛΩΝ ΛΑΒΕ!!!
JBearSVT is offline   Reply With Quote
Old 11-07-2009, 06:33 AM   #3 (permalink)
dhowton's Avatar
I Ride: 05 636
I have had my HIDs on for a few months now and I haven't had any issue with them drawing to much power. It might be that I just haven't had them on long enough. I also got a low wattage kit (35w). What wattage are you running? could have something to do with why you think they killed the stator.
Riding a race bike is an art - a thing that you do
because you feel something inside.
-Valentino Rossi
dhowton is offline   Reply With Quote
Old 11-07-2009, 12:07 PM   #4 (permalink)
Crazyninja's Avatar
I Ride: '08 ZX6R
HID's draw a lot of current upon starting. they revert back to less draw when warmed up. Mine blew my stock headlight fuse at first until i did a relay. Your stator probably just took a dump. probably not related to HID's. i am running heated jacket liner and heated grips, satellite radio, radar detector, cellphone charger, HID's. No problems with charging or volts.
kawasaki ecu's are tempermental to voltage. you can prove this by having a low batter charge just enough to crank the starter but the bike won't start because the ecu can't control the engine properly.
2008 ZX6R - candy plasma blue-stock battle axe tires, Healtech XTR-E, Gutted stock exhaust, PCIII - redneck tuned on an abandoned road-until the cops got called LOL
Crazyninja is offline   Reply With Quote
Old 11-07-2009, 01:41 PM   #5 (permalink)
ZX6Ray's Avatar
I Ride: 08 ZX6R
Holy shit dude... Your forgetting the heated cup holder too.
I just find it odd that my stator took a dump after only 2 years. Well I found one on ebay so as soon as it gets here I'm going to test the resistance and then pop her in and see what happens. I also found a voltage regulator for only $30 off an 07 with 1100 miles. I'll replace those two components since it's almost impossible to test the resistance on a VR. Hopefully this solves the issue and I can finally get my last dyno tune in.
I'm running the 35W Fsane (made in china) kit BTW. I doubt those kits have any sort of FCC regulations on electrical noise and whatnot. I'm wiring in a switch today so I can just turn them on when I'm at crusing speed to compensate for that initial amperage draw when they turn on.
Old 11-07-2009, 04:02 PM   #6 (permalink)
I Ride: 07 ZX6
Parts fail!!!! Check all the grounds and make sure you are not causing the stator to over heat.
I KICKED THE DRAGONS BUTT!
07 zx6r
carbon fiber:
sides
intake
rear cowl
front fender
bmc race filter
PCIII
rs-5 carbon full race exhaust
race velocity stacks
puig shark gaurd
hot bodies shield
woodcraft rear sets
pazzo short levers
jumper mod
fuel cap
bridgstone bto 2's
rear seat cowl
full race set plastics
GPR v4
stunt steel half cage
kr tuned sliders bar ends
ss fender eliminater
graves smog blog off plates
rear brake fluild relocted
mirror block offs
ksouc77 is offline   Reply With Quote
Old 11-07-2009, 07:34 PM   #7 (permalink)
ZX6Ray's Avatar
I Ride: 08 ZX6R
Already been that route. The stator is not grounding out. It's got an open hence why there isn't any resistance among the 3 leads.
I decided to throw out the HID kit. I don't want any "made in china" HID crap on my bike. I don't think "quality" is a factor with anything made in china BTW.
Harley Davidson Suzuki GSXR Ducati Forum Kawasaki Forum
V-Rod Forum GSXR Forum Ducati Monster Vulcan Forums
Harley Forum Suzuki SV Honda 600RR Kawasaki ZX Forum
Buell Forum Yamaha R1 Honda 1000RR Kawasaki ZX-10R
KTM Forum Yamaha R6 Honda Fury Forums Triumph Forum
Victory Forums YZF-R6 Forum Honda Goldwing Triumph 675
Can Am Spyder Aprilia Forum Sportbikes Forum BMW S1000RR Forum
