» Site Navigation |
» Motorcycle Forums
» Links |
07-04-2009, 01:01 AM
#1 (permalink)
Highsided at 30mph
I highsided at 30mph and my stator cap cracked... I heard people say there should be around only a quart of oil in there but after i picked my bike up, it seems like ALL the oil came out, is that suppose to happen or is something else messed up?
07-04-2009, 07:15 AM
#2 (permalink)
I Ride: '04 ZZR 1200
What they meant was that if you pull the cover with the bike upright, you'll only lose about a quart. Laying it on it's side, however, lets more oil into the cover. You could probably drain most of it like that.
07-04-2009, 08:58 AM
#3 (permalink)
Forum Leaders
I Ride: 2005 ZX6R
Sorry to hear you went down but it sounds like you made it out alright if you're already working on the bike. Good luck getting her put back together and getting out on the road again.
-Poetry written in gasoline.
07-04-2009, 09:02 AM
#4 (permalink)
I Ride: 08 ZX6R
How the heck did you high side at 30 mph??
Throttle up, knee down and pray.
07-04-2009, 12:06 PM
#5 (permalink)
going into a curve then i hit a bump my rear lifted a little, then i slightly hit the throttle a little too much.. went down
07-04-2009, 01:26 PM
#6 (permalink)
I Ride: 08 ZX-6R and 06 1600 Nomad
Glad you OK man. Get you some sliders man. $70-80 could have prevented that. Sorry about the bike.
Quick Daddy (Alan)
Jumper Mod, HealTech X-TRE, K&N Filter, Kawi Perf. Vel. Stacks, 15T -1 Fr/45T +2 R, Yoshi RS-5 Carbon, Pinebox Header, PCIII w/3rd Custom Map, Mobil 1 4T, M1-108 Filter, Santa has my Speedohealer Convertibars, TS Snake Skins, V2 Wind Screen, Kuryakyn Grips/Bar Ends/Throttle Boss, Air Hawk Seat, Puig Hugger, DIY Rear- pegs/mts removed, brake res. and tag re-locate, Vortex Frame & Pro Tek Swing Arm Sliders/Spools, "Backoff" stop light flasher, 35/30mm Static Sag (Fr/R)
07-04-2009, 05:06 PM
#7 (permalink)
I Ride: 08 ZX6R
Have you set your suspension sag up yet? 38mm front/30mm rear. Might be the problem along with compression and rebound dampening.
07-04-2009, 07:40 PM
#8 (permalink)
I Ride: 2008 ZX6R
Yeah, that's the first thing that I thought of when you said you highsided at 30, b/c its real tough to do. When I first bought my bike I had a couple scary moments with big bumps in turns and too much throttle, but then I got the sag set right, dialed in the compression and rebound and no more issues.
Akra Evo System/Jumper Mod/Scott's Steering Stabilizer/Speedohealer/Quick Turn Throttle/Cycle Sector Rearset Adjusters/Rear Res Relo/T-Rex Sliders&Spools/Rear Cowl/Pinebox v4.0/Red Gauge Cluster
Make this your homepage:
http://www.theanimalrescuesite.com/c...faces?siteId=3
You can click every day!
07-04-2009, 07:50 PM
#9 (permalink)
after everything is fixed im going to get it checked up and set up for my weight
07-04-2009, 09:58 PM
#10 (permalink)
i have a stator cover laying around. pm if you want it
