» Site Navigation |
» Motorcycle Forums
» Links |
07-02-2009, 06:43 PM
#1 (permalink)
I Ride: 08 ZX6R
3rd at 10k RPM....what the hell
I was riding home from work today and hit 3rd gear, needed to pass a car so I hit the throttle and when I hit about 10k rpms it felt like the gear slipped and it just revved as if the clutch was pulled in....any ideas why????
2008 ZX6r
Two Bros - SlipOn
Carbon Fiber Intake (Ram Air Mod)
HID 8000k
Blue Halos
905 Race Railz
2x Rear Screens
DB Screen
Jumper Mod
Blue LED Gauges
Blue LED Lights
....in the works
Power commander, TRE, -1 +3 sprockets, Speedo Healer, Racing Filter...
Graphics at Seemlez Design
Better to remain silent and be thought a fool than to speak out and remove all doubt.
-Abraham Lincoln
07-02-2009, 06:59 PM
#2 (permalink)
I Ride: '05 ZX6R
how fast were you going when you downshifted? were you close to 10k after you went down to 3rd, or did you go from like, 6k up to 10k and then it slipped?
2k5 Plasma Blue 636
Mods:
-1 Front Sprocket.
FE Kit, with a touch of DIY
Hopefully more to come over summer.
Summer Mods:
K&N Air Filter
EBC Gold Sintered HH Front Brakes
07-02-2009, 07:02 PM
#3 (permalink)
I Ride: 08 ZX6R
i wasn't downshifting just in 3rd and hit the throttle
2008 ZX6r
Two Bros - SlipOn
HID 8000k
Blue Halos
905 Race Railz
2x Rear Screens
DB Screen
Jumper Mod
Blue LED Gauges
Blue LED Lights
....in the works
-Abraham Lincoln
07-02-2009, 07:12 PM
#4 (permalink)
I Ride: 08' ZX-6R
are you using motorcycle specific oil? maybe your clutch slipped from using a car oil??? either that or your clutch is going
07-02-2009, 07:19 PM
#5 (permalink)
I Ride: '05 ZX6R
what brad said
2k5 Plasma Blue 636
Mods:
-1 Front Sprocket.
Summer Mods:
K&N Air Filter
07-02-2009, 07:31 PM
#6 (permalink)
I Ride: 08 ZX-6R and 06 1600 Nomad
How many miles man? What oil? Hopefully no additives right?
Quick Daddy (Alan)
Jumper Mod, HealTech X-TRE, K&N Filter, Kawi Perf. Vel. Stacks, 15T -1 Fr/45T +2 R, Yoshi RS-5 Carbon, Pinebox Header, PCIII w/3rd Custom Map, Mobil 1 4T, M1-108 Filter, Santa has my Speedohealer Convertibars, TS Snake Skins, V2 Wind Screen, Kuryakyn Grips/Bar Ends/Throttle Boss, Air Hawk Seat, Puig Hugger, DIY Rear- pegs/mts removed, brake res. and tag re-locate, Vortex Frame & Pro Tek Swing Arm Sliders/Spools, "Backoff" stop light flasher, 35/30mm Static Sag (Fr/R)
07-02-2009, 11:01 PM
#7 (permalink)
I Ride: 08 ZX6R
Put amsoil oil in at 6000 miles 10w40 full synthetic motorcycle oil
2008 ZX6r
Two Bros - SlipOn
HID 8000k
Blue Halos
905 Race Railz
2x Rear Screens
DB Screen
Jumper Mod
Blue LED Gauges
Blue LED Lights
....in the works
-Abraham Lincoln
07-02-2009, 11:10 PM
#8 (permalink)
I Ride: 2000 ZX9r
Is your clutch cable adjusted right? You should have a little play in the lever when it's all the way out.
07-03-2009, 02:04 PM
#9 (permalink)
I Ride: 2008 Kawasaki ZX6R
does it still do it or was this a one time thing?
Tim
2008 ZX6R
DB smoke windshield
Frame sliders
Jumper Mod
-1 + 1 gearing
HealTech speedohealer
HealTech X-TRE
Velocity stacks
07-03-2009, 09:27 PM
#10 (permalink)
Forum Leaders
I Ride: 2005 ZX6R
Check your clutch cable adjustments at both ends. If the problem persists, then you may have a cooked clutch.
-Poetry written in gasoline.
07-06-2009, 12:16 PM
#11 (permalink)
I Ride: 2008 ZX-6r
 with shifty.
2008 ZX-6r : Yoshi RS-5, 5150 rearset risers, Pinebox taillight, removed reflectors, relocated license plate, jumper mod
07-06-2009, 01:06 PM
#12 (permalink)
I Ride: 08 ZX6R
clutch cables seem to be fine and there is play in the clutch handle, can't see what a clutch would burn out at 6000 miles....
2008 ZX6r
Two Bros - SlipOn
HID 8000k
Blue Halos
905 Race Railz
2x Rear Screens
DB Screen
Jumper Mod
Blue LED Gauges
Blue LED Lights
....in the works
-Abraham Lincoln
07-06-2009, 01:15 PM
#13 (permalink)
how long did it happen?
maybe you were just spinning up the rear tire.
07-06-2009, 01:31 PM
#14 (permalink)
Forum Leaders
I Ride: 2005 ZX6R
It all depends on how you ride it. Burnouts, wheelies, improper adjustment, etc. can cook a clutch pretty quickly.
07-06-2009, 02:03 PM
#15 (permalink)
I Ride: 08 ZX6R
never thought could be spinning the tire....
It didn't happen for to long, once I noticed it I let off of the throttle and then back on and kept riding....
I tried to see if it would happen again and red-lined it in gears 2-5th and ran smooth so I have no idea...
No wheelies or anything, don't ride the clutch to hard, I do downshift/engine break whenever I am coming to a light I don't just hold in the clutch and kick it down to first when I am sitting at the light but don't think that is a problem.
2008 ZX6r
Two Bros - SlipOn
HID 8000k
Blue Halos
905 Race Railz
2x Rear Screens
DB Screen
Jumper Mod
Blue LED Gauges
Blue LED Lights
....in the works
-Abraham Lincoln
07-07-2009, 02:22 AM
#16 (permalink)
I Ride: 09 ZX-6r (M E)
As noobish as it sounds this happened to me a few times in second on my brothers 650r, only did it when I didn't put it in gear firmly enough.
Riders have nothing to hide, that's why we don't sit around inside.
2009 Kawasaki Ninja ZX-6r Monster Edition
07-07-2009, 04:06 AM
#17 (permalink)
I Ride: 2000 zx6j
Agreed!
adam (choirboy)
07-07-2009, 09:16 AM
#18 (permalink)
I Ride: 08 ZX6R
thanks for everyone's help, it hasn't happened since so I suppose everything is fine, clutch seems to be working like it should so it could of been just not in gear like USAFZixxer said....
2008 ZX6r
Two Bros - SlipOn
HID 8000k
Blue Halos
905 Race Railz
2x Rear Screens
DB Screen
Jumper Mod
Blue LED Gauges
Blue LED Lights
....in the works
-Abraham Lincoln
07-10-2009, 01:43 PM
#19 (permalink)
About the thickness of a nickel.
07-16-2009, 11:23 AM
#20 (permalink)
I Ride: ZX6R '07
Yeah, I would go with you havent engaged the gear properly, and then it went in itself. I have done that myself a couple of times, dont think it would be anything sinister.
ZX6R '07 Pearlfire Orange, K&N Filter, Akrapovic Can, Power Commander V, Dynojet custom tuned, Clear Indicator Lenses, Orange rear wheel, Shogun crash protectors, Amber nose LED, Pazzo levers, Carbon Fibre heel guards, Carbon Fibre side panels, Galfer wave rear disc, loads of Ti bolts  114.6whp
