My '08 zx6r seems to have no balls until 8000 rpms. You have to keep the revs up. Mine will ping with premium gas if you lug the engine down low. With 13.3:1 compression that is seriously pushing the limits of pump gas. You may want to try a different brand of gas. Here when I buy speedway gas w/ ethanol blend my bike pings like hell.
If I use Exxon gas it does not hardly ping at all. Even when it is hot outside.
You could also do a manual toggle switch on your engine fan and keep it on all the time to cool the engine down more. That will reduce your detonation too.
My bike never goes above 170 F and normally hovers around 158-163F with the fan on all the time.
On my '08 I ran a 16 awg wire from the positive batter cable with a 10 amp inline fuse next to the batter to a lighted LED toggle switch up front. Then ran the wire from the switch to the (Blue) fan wire. This way I have full control of the fan without waiting for the engine to get to 216 F to come on only to cool it down to 205 F and turn off.
You have to remember to turn the switch off when you get off your bike or you will kill your battery fast.
I figure this will make the engine live longer on hot summer days.
2008 ZX6-R, K&N filter,8000K HID (15 more hp) Jumper Mod, PCIII, Gutted stock muffler (Hillbilly slip-on) w/ butterfly valve removed. Rear fender removed w/plate on swingarm.
Sirius sat radio, Bell radar detector (both worth 10 rwhp gain) Listening to Sirius 20 rockin down the highway
