I am trying to remove the right side fairing. I have removed all bolts and push pins from outside of fairing and the inside by the tire, but it still seems to be stuck on the turn signal. Help????
there is a little clip where the bottom of the side fairing meets the belly pan. if i remember correctly you have to work the belly pan front to back to get it to come loose.
Thanks I will try that. Do you have to remove the turn signal separate from the fairing?
No the turn signal will come off with the fairing.
Go to this site http://www.ninja6zone.com/forums/ and register with them and then go to the File Vault section and download the manual and it will tell you all you want to know.
AIRFORCE OIF
Blue Halo lights
Extra bright head lights
PCIIIUSB
removed secondary butterflys
Jumper Mod
T-Rex frame sliders
DIY finder eliminator
Gutted Cat
CF Scorpion Slip-on
pro-grip Gel grips
kleen Air mod
Ram Air Mod
Blue ZX6R
Check out my 25 dollar halo lights!!! http://i46.photobucket.com/albums/f1...6/CIMG1147.jpg
my bad i should have stated what i said better, twist the bulb, the actual triangular housing is attached to the fairing and will come off with it, sorry
