ATV.comBikeBanditSpringfield ArmoryCycleGear.comSuperbikeToyStore.comMotorcycle.com Classifieds!CheapCycleParts.comSportbikeTrackGearJazzMotorsports.comAdvanstarMotorcycleShows
CycleGear.com
Old 09-01-2008, 05:30 AM   #1 (permalink)
how to stop the red light blinking
how can i stop the red light blinking at my dashboard...when i turn the key on it blinks,then why is it when i start the bike its keep on blinking is it normal or theres something wrong into my bike.what does the red light blinks means thanks...
rsanpedro is offline   Reply With Quote
Old 09-03-2008, 03:25 AM   #2 (permalink)
okei sir thanks for the info
Old 09-03-2008, 03:58 AM   #3 (permalink)
it keeps on blinking even the engine is running bubt it says that there is an error 63 on the bike..what' the meaning of the error 63.
Old 09-03-2008, 11:08 PM   #4 (permalink)
lil_shane84's Avatar
I Ride: 08 ZX6-R S.E.
Service Code Table
Service Code Problems
11 Main throttle sensor malfunction, wiring open or short
12 Inlet air pressure sensor malfunction, wiring open or short
13 Inlet air temperature sensor malfunction, wiring open or short
14 Water temperature sensor malfunction, wiring open or short
15 Atmospheric pressure sensor malfunction, wiring open or short
21 Crankshaft sensor malfunction, wiring open or short
23 Camshaft position sensor malfunction, wiring open or short
24 Speed sensor malfunction, wiring open or short
25 Gear position switch malfunction, wiring open or short
31 Vehicle-down sensor malfunction, wiring open or short
32 Subthrottle sensor malfunction, wiring open or short
33 Oxygen sensor #1 inactivation, wiring open or short (Equipped Models)
34 Exhaust butterfly valve actuator sensor malfunction, wiring open or short
35 Immobilizer amplifier malfunction
36 Blank Key detection
39 ECU communication error
51 Stick coil #1 malfunction, wiring open or short
52 Stick coil #2 malfunction, wiring open or short
53 Stick coil #3 malfunction, wiring open or short
54 Stick coil #4 malfunction, wiring open or short
56 Radiator fan relay malfunction, wiring open or short
62 Subthrottle valve actuator malfunction, wiring open or short
63 Exhaust butterfly valve actuator malfunction, wiring open or short
64 Air switching valve malfunction, wiring open or short
67 Oxygen sensor heater malfunction, wiring open or short (Equipped Models)
83 Oxygen Sensor #2 inactivation, wiring open or shout (Equipped Models)
94 Oxygen sensor #1 malfunction, wiring open or short (Equipped Models)
95 Oxygen sensor #2 malfunction, wiring open or short (Equipped Models)
Ex-Con Freeride: "Fight The Conviction!"
lil_shane84 is offline   Reply With Quote
Old 09-05-2008, 05:45 AM   #5 (permalink)
sir can you tell me what can i do to sold the problem is that serious or ill just ignore it...what cna be the cause to my bike if ever i dont pay attention to it..
Old 09-05-2008, 11:34 AM   #6 (permalink)
i would recommend taking it to the dealer
Old 09-05-2008, 12:27 PM   #7 (permalink)
Kick Stand
That red light is when your kick stand is down......
wintercamper69 is offline   Reply With Quote
Old 09-08-2008, 11:52 PM   #8 (permalink)
mr.nubbins@mac.com's Avatar
My o8 zx 6r red light blinks for about 4 seconds after I start the bike, is that normal? When i first started the bike I noticed the light and froze in fear thinking where did the oil go I just checked it! then it stopped blinking. So is a 3 or 4 second blink after you start the bike normal! Or should I take the bike to the dealer?
mr.nubbins@mac.com is offline   Reply With Quote
Old 10-04-2008, 11:13 AM   #9 (permalink)
My 06 zx10 has a "fi" flashing in the display with a flashing red light next to it, but it doesn't have a code number. How can I get the number? (all the local dealers have a 3 week backlog)
trailrigg is offline   Reply With Quote
Old 10-04-2008, 11:42 AM   #10 (permalink)
SLIDER's Avatar
I Ride: 2007 ZX6R,KX125
completely normal
trailrigg- disconnect the battery for 10 minutes. then restart the bike. if the light is still there then take it to a dealer. or download the service manual from kawi
2007 ZX6R
Catalytic converter cut out
Emissions system removal
PCIIIUSB custom map
Jumper Mod
BMC race filter
Kawasaki velocity stacks
Vortex clip-ons
Vortex rearsets reverse shift
PowerBronze DB windscreen
Hyper Co rear spring
Sato front axle sliders
Old 10-04-2008, 05:48 PM   #11 (permalink)
Mikew18's Avatar
I Ride: 2007 Zx6R (Special Edition)
You need to fix your bike like now! My friend had the same thing happen and it's because your VTEC solenoid is malfunctioning. Go to Honda first to fix the VTEC thingy then to kawasaki to have them rotate your engine.
2007 ZX6-R(p)
Jumper Mod
Two Brothers Carbon Exhaust
Chrome Mid Pipe
Gutted Cat
Micheline Pilot Road 2ct's
Two Bros Juice Box Fuel Management
ASV Shorty Levers
Puig DB Windscreen
Hid 6k Headlamps
ProGrip 724 Gel Grips
Mikew18 is offline   Reply With Quote
Old 10-04-2008, 06:58 PM   #12 (permalink)
njzx6's Avatar
Did you put an exhaust on, or is the stock one still on? If you've changed the exhaust, do a search on this forum and you will kind the remedy to stop the light from blinking. One more thing, is there an F1 showing on the LCD? If there is then the problem is the exhaust butterfly.
njzx6 is offline   Reply With Quote
