» Site Navigation |
» Motorcycle Forums
» Links |
08-30-2008, 09:24 AM
#1 (permalink)
I Ride: 2003 ZX6
pics of fall,,,need advice!!!
08-30-2008, 11:14 AM
#2 (permalink)
I Ride: 2007 ZX6R,KX125
up to you whether you want to fix it or not. you could touch it up a little so you don't have any black marks. But if it bothers you that much then replace it. They don't look like they're about to fall off so I wouldn't worry about it...
2007 ZX6R
Catalytic converter cut out
Emissions system removal
PCIIIUSB custom map
Jumper Mod
BMC race filter
Kawasaki velocity stacks
Vortex clip-ons
Vortex rearsets reverse shift
PowerBronze DB windscreen
Hyper Co rear spring
Sato front axle sliders
08-30-2008, 11:38 AM
#3 (permalink)
I Ride: 2003 ZX6
new paint and a fiberglass repair kit should do the trick i hope..
08-30-2008, 03:12 PM
#4 (permalink)
I Ride: 2003 ZX6
construction is in progress. sanded down all scratches which eliminated about 30%. using resin to eliminate the deep scratches and waiting to sand now...plan on filling crack with a fiberglass repair kit?? would that do the trick??? and then painting :) sound dandy?
08-30-2008, 03:42 PM
#5 (permalink)
sounds good except for the resin on plastic part. I don't know if it's just the stuff I use, but fiberglass resin doesn't seem to stick to plastic very well. Give it a try. couldn't hurt
2007 ZX6R
PCIIIUSB custom map
Jumper Mod
BMC race filter
Vortex clip-ons
08-30-2008, 05:20 PM
#6 (permalink)
I Ride: 2003 ZX6
so what should i use to patch the crack? it fits in perfect, nothing missing where the crack is...what should i do/use?
08-30-2008, 05:46 PM
#7 (permalink)
I Ride: 97 Ducati 900 SP
if it's a stock fairing... it's an abs plastic... polyester fiberglass resins will stick... you just have to do a little prep.
in the area you want to patch..hopefully the inside of the piece... behind the painted surface.. sand it a bit ...break the surface.. blow off the dust. use some acetone on the surface... won't take too much at all... very little.. with a small chip brush (disposable.. firm bristles). . scrub the "to be patched area".. not to rough... kinda like brushing your teeth..
do it once... let it sit for 5 minutes... and repeat... the surface should be tacky.. (sticky)..
then take a little cup of the resin (polyester).. it will be easier if the resin is thickened up a little bit at this point.. use cabosil, poly-fibre, or normal baby powder will work... before adding the hardener (MEK-P) to the resin..add a little powder.. mix with a small stick.. add powder till the resin is like a milk shake.. this is also referred to as MUD.... this will help the resin stay where you want it.. so it doesn't drip all over the place... add 2 percent MEK-P to the mud.. stir well... add mud to the tacky area... add one or two layers of fiberglass cloth.. tap out so the cloth with a chip brush till the cloth is no longer white.. and it absorbs the resin... let harden.. sand..
sounds like a lot more work then it is... it will be easy to fix.. and save you money..
also.. if you're gonna work with resins... do it in a ventilated area.. use a fan, and where a respirator...
a new piece of fairing may be sounding pretty good right now... but give the fix a go.. you want to see someone working with fiberglass... check you-tube... you'd be surprised.. there may be a video showing how to this already...
08-30-2008, 08:31 PM
#8 (permalink)
I Ride: 2007 Custom ZX14, 2003 Honda VTX 1800C My lady rides a ZX9
GET BETTER FRAME SLIDERS!!!! There is no way they should have sheared off or cracked after a fall from less than 10 mph. Please invest a few more bucks into a good pair. They are an important and functional upgrade for your bike. Hope you're back riding soon and your body heals quickly.
Keep the sticky side down
09-09-2008, 10:10 AM
#9 (permalink)
What kind of frame sliders did you have?
09-10-2008, 10:04 PM
#10 (permalink)
I Ride: 2006 zx6r
I have Motovation frame sliders. Never had to use them. They are good quality right???? I dont want this happening to me!
09-10-2008, 10:40 PM
#11 (permalink)
I Ride: 2007 ZX-6R
bet you $10000000000000000000 you had no-cut frame sliders! lol
SS LED Fender Eliminator Kit
Jumper Mod
Custom Tuned PCiii
Akrapovic Evo 4-2-1 Full Exhaust System w/ Hex
Solo Seat Cowl
Puig Dark Racing Windscreen
Puig Rear Hugger (green)
K&N Air Filter
Removed Passenger Pegs
Relocated Rear Brake Resivor
Shogun Crash Kit (cut fairing)
Carbon Fiber Mirrors
09-11-2008, 08:05 AM
#12 (permalink)
Thats what i was thinking
09-11-2008, 09:24 AM
#13 (permalink)
I Ride: 2008 ZX6R
not to argue, but those look like more than 7mph scratches... i see lots of wrecked bikes. I doubt he was being an idiot, but maybe around 20mph...still the frame sliders shouldn't have broken off...
'08 Highlighter ZX6R
So Far: Puig tinted double bubble screen
Clear tank pad
Solo seat cowl
Shogun Frame Sliders
Removed passenger pegs
Relocated rear brake line
Jumper Mod
Removed Chicken strips!!!
09-11-2008, 01:36 PM
#14 (permalink)
I Ride: 2003 Kawasaki ZX-6R 636 (silver)
Hell I went down hard at the racetrack, slid on the side of the bike for a while then went flipping into the air with a not so pretty landing. One of my frame sliders ground halfway down, but nothing snapped off.
You wouldn't think one would just snap off like that with a low speed landing. What's the point of a frame slider if the slider breaks off first thing?
