Racer Parts WholesaleSuperbikeToyStore.comATV.comCycleGear.comSportbikeTrackGearSpringfield ArmoryMotorcycle.com Classifieds!AdvanstarMotorcycleShows
Old 08-28-2008, 05:03 PM   #1 (permalink)
I Ride: '08 ZX6R
Installed my pcIII today
Install wasn't too bad. I did remove the fuel tank just to make it easier and I completely removed the air box.
Installed the pcIII in the storage area under the passenger seat and routed cable harness down the left side of the bike (if you were sitting on the bike).
I wasn't sure or if it even mattered which set of wires looped each injector so I just plugged them in from the pcIII in consecutive order from left to right.
Then I used the tap and tapped the lower harness plug on the tps (yellow) wire.
When I first connected everything back the bike ran like shit and wouldn't idle.
I had the two wiring plugs on the tps reversed. Got that fixed and all is good.
I loaded a map that Zxray gave me for my setup.
Haven't got to ride the bike yet. It will be Saturday for that.
I will let everyone know how it goes.
I thought about getting the ignition module from Dynojet. Is it beneficial to alter the ignition timing on these zx6r's ?
2008 ZX6-R, K&N filter,8000K HID (15 more hp) Jumper Mod, PCIII, Gutted stock muffler (Hillbilly slip-on) w/ butterfly valve removed. Rear fender removed w/plate on swingarm.
Sirius sat radio, Bell radar detector (both worth 10 rwhp gain) Listening to Sirius 20 rockin down the highway
Crazyninja is offline   Reply With Quote
Old 08-28-2008, 06:04 PM   #2 (permalink)
Gumby's Avatar
I Ride: 2006 ZX-6R
There is a specific way to plug them in, but yes it is pretty much from left to right if you are following the cord which you put on the left side. But congrats! Hope it runs well, mine gave me some problems at first but I fixed it! Remember, sometimes it takes 10-25 miles for the ECM to adjust, mine did at least.
Gumby is offline   Reply With Quote
Old 08-28-2008, 09:19 PM   #3 (permalink)
nonelower2001's Avatar
I Ride: Blue 08 ZX6R
crazyninja what map did you get and what is it for?
AIRFORCE OIF
Blue Halo lights
Extra bright head lights
PCIIIUSB
removed secondary butterflys
Jumper Mod
T-Rex frame sliders
DIY finder eliminator
Gutted Cat
CF Scorpion Slip-on
pro-grip Gel grips
kleen Air mod
Ram Air Mod
Blue ZX6R
Check out my 25 dollar halo lights!!!
http://i46.photobucket.com/albums/f1...6/CIMG1147.jpg
nonelower2001 is offline   Reply With Quote
Old 08-28-2008, 10:21 PM   #4 (permalink)
ZX6Ray's Avatar
I Ride: 08 ZX6R "Slimer"
It's my dyno tuned map I gave to him because he is going with a similar setup.
I have K&N, Akra slip on, gutted cat and the smog crap removed with plates installed on the valve cover.
The jumper mod doesn't matter because all it does is return the ignition advance back to normal after 12,000 rpm and up. They retard the ignition timing in the factory because of the exhaust valve restricting the exhaust at higher rpm's. It has nothing to do with fuel delivery.
Well Done 8000K HID Headlight Kit
Shogun No-Cut Frame Slider kit
Kawasaki Seat Cowl
Racing Footpegs
Passenger Foot pegs Removed
SMOG Crap Gone! Blocks installed!
Gutted Cat
Akrapovic Slip-on
PCIII with Custom Tuned Map
Jumper Mod
K&N Filter
Competition Werkes Fender Eliminator Kit
Puig Carbon Fiber Hugger
Ninja Tank Pad
Front Reflectors Gone
Rear Brake Resevoir Relocation
Blacked Out Windscreen
Monster Racing Decal Kit
2007 Green Belly Pan
Pazzo Racing Levers
ZX6Ray is offline   Reply With Quote
Old 09-01-2008, 11:18 AM   #5 (permalink)
I Ride: '08 ZX6R
My smog stuff is still there except for a gutted cat and gutted stock muffler.
I did have a dead spot around 40-50% part throttle with the map you gave me.
It screamed on top end and idled good.
I didn't have my wideband in the tailpipe to tell if it was lean or rich on my bike.
It felt lean Maybe? I am not sure.
I loaded the "akra full system map for 07-08 zx6r" and it took care of the part throttle issue but I felt like a lost some on top.
I will play around with it and let you know.
Old 09-01-2008, 12:19 PM   #6 (permalink)
ICEMAN2087's Avatar
I Ride: 2007 ZX6R
does gutting you muffler make it louder or what... probably a dumb question but im tech dumb
ICEMAN2087 is offline   Reply With Quote
Old 09-02-2008, 08:48 AM   #7 (permalink)
I Ride: 07 Ninja ZX6R
it does indeed... it sounds like an aftermarket slip on
catchin me ridin down i10 well im stuntin on my zixxer lol
MY BITCH FOR SALE
http://elpaso.en.craigslist.org/mcy/824625267.html
pacmanzx6 is offline   Reply With Quote
Old 09-03-2008, 03:14 AM   #8 (permalink)
I Ride: '08 ZX6R
It does sound just like an expensive slip on except you still have all the heavy weight from the factory pieces. I am happy with the sound and the bike "feels" like it runs better. Maybe it does.....Maybe not, but I like it. Exhaust would have to flow better without the cat, butterfly valve, muffler baffles that caused reverse flow in the muffler.
Muffler is straight through now.
