BikeBanditSpringfield ArmorySuperbikeToyStore.comCycleGear.comJazzMotorsports.com5150 ConceptsMotorcycle.comCheapCycleParts.com
Racer Parts Wholesale
Old 07-08-2008, 01:11 PM   #1 (permalink)
LT1MAN's Avatar
I Ride: '06 flat blue 636
where to mount tag???
i bought an rs-5 and an integrated tail light for my 06. now i just need to figure out how to mount the tag up underneath. i have all the capabilities to fab any type of brackets necessary, i just don't want to go drilling into the wrong things.
in the pic below i've highlighted the general area where i would like the tag to be. however i dont know what that part is right there and i dont want to put holes where holes dont need to be. please advise.
LT1MAN is offline   Reply With Quote
Old 07-08-2008, 01:15 PM   #2 (permalink)
I Ride: 2005 zx-6r (sold) 07 GSX-R1000 now
My guess would be the battery sits there and/or some type of electrical stuff
2005 zx-6r (sold, it was a lemon)
2006 cbr1000rr (quick purchase to help a friend)
2007 GSX-R1000 (oh so nice!)
dumped_it is offline   Reply With Quote
Old 07-08-2008, 01:18 PM   #3 (permalink)
LT1MAN's Avatar
right on, would you feel safe shooting a self-tapping screw threw that? do people even screw these things on or is there some type of adhesive that would hold up to the elements.
Old 07-08-2008, 01:36 PM   #4 (permalink)
SLIDER's Avatar
I Ride: 2007 ZX6R,KX125
your battery sits in front of that area. DO NOT drill from the outside. There are to many wires and electronics. Actually, I'm pretty sure the ECU sits right there.take the seat off and move everything out of the way so that you can drill from the inside.
2007 ZX6R
Catalytic converter cut out
Emissions system removal
PCIIIUSB custom map
Jumper Mod
BMC race filter
Kawasaki velocity stacks
Vortex clip-ons
Vortex rearsets reverse shift
PowerBronze DB windscreen
Hyper Co rear spring
Sato front axle sliders
Old 07-08-2008, 01:47 PM   #5 (permalink)
LT1MAN's Avatar
ahh, great thanks! thats what i needed to know.
Old 07-08-2008, 02:23 PM   #6 (permalink)
Forum Leaders
Shifty1's Avatar
I Ride: 2005 ZX6R
Or, if you wanted to go the "I need to ride right now and only want to spend 15 cents to hang my tag" route, I have heard of guys running zip ties from the corners of the plate to the passenger peg mounts. Ooorrr, if you like the look of a hugger, there is one that comes with a license plate mount on the top of it. Ooorrr, you could reverse engineer the Competition Werkes setup.
Old 07-08-2008, 09:47 PM   #7 (permalink)
NjNinJa's Avatar
I Ride: 08 Zx6R
My 2 cents...If ya want to mount it flat on that piece, i say fuck it, get some apoxy and stick that shit on... but if you want it to hang straight down, then u have to come up with somthing better...
Jersey N-werD
NjNinJa is offline   Reply With Quote
Old 07-08-2008, 10:30 PM   #8 (permalink)
CUCULANDRA's Avatar
I Ride: 2007 ZX10R SE
What Year Lt1 You Own?
CUCULANDRA is offline   Reply With Quote
Old 07-08-2008, 10:56 PM   #9 (permalink)
zx636's Avatar
I Ride: minty 05 zx6r
i just put my plate in the same place the other day. you need to take the seat off and the ecu out. i found it easier to use a hot soldering gun to burn holes through the undertail, it does a much nicer job than a drill. make sure that you put some type of silicone on the bolts that you run through the undertail to mount the plate to avoid getting water on the ecu. you will also need to put two extra washers on the bolts holding the ecu down to make clearance for the bolt heads that are sticking up under the ecu. hope that helps.
zx636 is offline   Reply With Quote
Old 07-09-2008, 06:44 AM   #10 (permalink)
LT1MAN's Avatar
its a 94
http://www.zxforums.com/forums/zx-6r...-question.html
njninja, it definitely needs to lean, i think it will hit the tire if it goes straight down. i can't really stick it on flat bc those 2 nuts sticking out.
on the 45 degree part right under that i could stick it there, but it would only allow for adhesive to cover half of the back of the plate.
i was thinking i might could just put 2 little 45 degree L brackets off of the square nuts in the red circles.
Old 07-09-2008, 08:04 AM   #11 (permalink)
zx636's Avatar
you will have to put a pretty good bend in the plate if you mount it that far back. if you put it where you originally wanted it you only need to put a slight bend on the plate to avoid the tire. i have been riding mine for a week now and i havent had any tire contact, it dosent even look like there is a anyway the plate could hit.
Old 07-09-2008, 11:03 AM   #12 (permalink)
LT1MAN's Avatar
hmmm, i see what you mean. would you happen to have any pics of yours tag setup? or anyone else for that matter have any pics?
Old 07-09-2008, 06:07 PM   #13 (permalink)
NjNinJa's Avatar
I Ride: 08 Zx6R
i think ur idea with the L brackets is just fine... bend the brackets themselves, and even ziptie the plate to em... i took off my rear hitch lookin thing, and ziptied the plate right to the bracket there... but that's only temporary...
Jersey N-werD
Old 07-09-2008, 10:28 PM   #14 (permalink)
zx636's Avatar
whatever you do dont use zip ties it will look like shit more than likely. just take your time and put something together that will look good. if you spend the time doing it right you will be much happier with the end result.
as for pictures, my digital camera is broken but ill see what i can do.
Old 07-09-2008, 10:55 PM   #15 (permalink)
NjNinJa's Avatar
I Ride: 08 Zx6R
I used some nice thick black zip ties... u cant even tell they're zip ties... but like i said, it's only temporary...
Jersey N-werD
Old 07-10-2008, 07:48 AM   #16 (permalink)
LT1MAN's Avatar
yea only way i would use zipties is to get me to the hardware store to get some nuts & bolts.
Old 07-10-2008, 06:14 PM   #17 (permalink)
Weeks208's Avatar
I Ride: 2006 Kawasaki Ninja 636
put this on my bike a few years
Weeks208 is offline   Reply With Quote
Old 07-11-2008, 07:32 AM   #18 (permalink)
LT1MAN's Avatar
yea thats a good looking setup there i looked at those.
Old 07-12-2008, 12:28 PM   #19 (permalink)
zx636's Avatar
fially got some pics i hope these help
http://i247.photobucket.com/albums/g...uck412/003.jpg
http://i247.photobucket.com/albums/g...uck412/002.jpg
http://i247.photobucket.com/albums/g...uck412/001.jpg
