MotorcycleToyStoreBikeBanditJazzMotorsports.com5150 ConceptsD2MotoMotorcycle.comATV.com
Old 05-30-2008, 05:38 PM   #1 (permalink)
I Ride: 2007 Kawasaki Ninja ZX6R
does anyone know a DIY for fender eliminator '07 ZX6R
I searched but no luck so hopefully someone out there can point me in the right direction for a homemade fender eliminator. Thanks
Junito
Junito is offline   Reply With Quote
Old 05-30-2008, 07:35 PM   #2 (permalink)
SLIDER's Avatar
I Ride: 2007 ZX6R
I made my own. It mounts right in front of your tire to the undertail. Take the stock license plate mounting bracket and bolt it to the undertail. bolt the license plate to it by the bottom mounting points. get a "stopper" light. It has a running light, brake, and blinkers in 1 bar. get 2 "L" brackets and bend slightly. You will probably have to drill new holes toward the bend so that you can mount the stopper light. mount the stopper light below the license plate and you're done. be sure to mount it high enough that it won't hit the tire.
2007 ZX6R
Catalytic converter cut out
Emissions system removal
PCIIIUSB custom map
Jumper Mod
BMC race filter
Kawasaki velocity stacks
Vortex clip-ons
Vortex rearsets
PowerBronze DB windscreen
Hyper Co rear spring
Shogun frame sliders
Old 06-07-2008, 05:56 PM   #3 (permalink)
bjohnzx6r's Avatar
I Ride: '08 ZX6R
Another way...
That sounds like a pretty effective way of eliminating the whole (slightly obtrusive) rear setup. But if you're just looking to eliminate the fender itself, then you could do what I did and make a license plate bracket that bolts on to those 4 fender bolts (with a few cheap parts and some spray paint from your local OSH or Home Depot). Here's some pics...
Oh, and FYI the illumination from the brakelight lights up the plate somewhat decently...though I'm still contemplating getting a license plate LED light.
Hope this helps...
'08 ZX-6R Blue
'06 Acura TL Blue
bjohnzx6r is offline   Reply With Quote
Old 06-08-2008, 04:12 PM   #4 (permalink)
njzx6's Avatar
Junito
Where in NJ are you? I in the Fort Dix area....lmk, I can help with the FE.
njzx6 is offline   Reply With Quote
Old 06-08-2008, 06:01 PM   #5 (permalink)
Thanks for the info guys gonna try something when I get some free time again. I'm in Central jersey
Old 06-10-2008, 06:34 PM   #6 (permalink)
Hey BJOHNZX6R where did you get that bracket and what did you do with the license plate light.
Old 06-11-2008, 11:00 AM   #7 (permalink)
bjohnzx6r's Avatar
I Ride: '08 ZX6R
I just PM'ed you and if you look below the last pic I posted I address the license plate light.
'08 ZX-6R Blue
'06 Acura TL Blue
Old 06-11-2008, 05:52 PM   #8 (permalink)
what did you do to your license plate light? did you cut it off or rewire it somewhere else, I don't know what to do with it.
Old 06-12-2008, 05:50 AM   #9 (permalink)
_supermario90_'s Avatar
I Ride: 08 ZX-6r
I kept the wire to the socket and elec taped the socket end, then taped it to an inconspicuous location in the tail area.
I have seen cruisers with license plate bolts that actually are directional lights, so I plan on stopping in at a couple of local area shops to see what I can find and hopefully get legal again.
I don't do much riding at night, but at the same time, those are usually the times I don't want to give them a reason to pull me over.
_supermario90_ is offline   Reply With Quote
Old 06-12-2008, 04:59 PM   #10 (permalink)
thanks when I mess with it again I'm gonna try and rig it somewhere that it still lights up the plate, but I'll let you guys know if I work something out good. thanks
Old 06-12-2008, 06:44 PM   #11 (permalink)
bjohnzx6r's Avatar
I Ride: '08 ZX6R
License plate light...
Yeah, you can actually disconnct the light from underneath the drivers seat. Thats where all the rear lights are plugged in. It takes a little bit of disassembling, but thats the fun part right?
Oh, and yeah the license plate light bolts were going to be my next purchase as well. You can find them for around 16-18 bucks on ebay. Until then, my brakelight lights it up pretty well...
'08 ZX-6R Blue
'06 Acura TL Blue
Old 07-09-2008, 03:56 AM   #12 (permalink)
zioles's Avatar
I Ride: ZX-6r 2007
It might help you. First item on:
http://www.fourstrokesonly.com/LicensePlateLights.html.
I did something similar to BJOHNZX6R with the bracket. The light has glue on top so you can stick it to the bottom of the rear light...and secure with licence plate.
Holds well for the last 4 months…
zioles is offline   Reply With Quote
Old 07-09-2008, 06:03 AM   #13 (permalink)
nonelower2001's Avatar
I Ride: Blue 08 ZX6R
Thumbs up Tail light
I got this from ZX-6racer on the forum and it worked great for me. if you do a search for monster you will find his bike and he has a video of how the light looks. Stock tail light and some LED blinkers.
AIRFORCE OIF
Blue ZX6R
nonelower2001 is offline   Reply With Quote
Old 07-09-2008, 06:58 AM   #14 (permalink)
hyperionjr's Avatar
I Ride: 08 ZX6R
Is it still a "DIY" if you don't do it yourself?
Just joking. I bought mine. I was scared I would screw it up.
WILL
OIF 1 VETERAN and U.S. Supporter (Regardless of who we are beating up.)
hyperionjr is offline   Reply With Quote
