Originally Posted by sharka
i have one fitted to my zx14 it gives the low down power the zx is missing. (u can take the flys out and do the same). also the unit has a built in gear indicator as the standard one shows the gear set by the gl pro(which u can select). i think it is worth the money.
yea man thanks i ordered one last week nothin but great things about them the flied out thing aint the way to go not only do you void warranty but if you try to put them back in you could fry the plastic gears in the unit and end up buying 1050.00 carb assembly like i had to...the ivans tre did the job but you lost alot of crap with it neutral indicateres and such ,,, so i waited and now an excellent one is available.......and next to no latency on the gear indicator i got a speedo healer too...
