I rode my bike from work one day,and park it under the garage.The next day i tried to start it,and it didn't, it turns over,but not start. The fuel pump dosn't come on nor dose the secondaries files accuate.Check the fuses,and the tilt sensor.Thinking it might be the relays they click when the switch is on,plus their in a seal box. please help:headscrat ch
You're not getting a code on the dash-something sayin "FI error"?Or anything like that with a red light flashing off to the side?If you are-turn the key on-push BOTH reset and mode buttons and hold for around 3,4 seconds till the code number displays.That will tell you what's going on.You can also check your codes this way even if it's not showing an error on the LCD.Key on-push both for 3,4 seconds and if there's an error in there,it will display a number.Look that up in the service manual under DFI section-it should be listed in there.tszczk sound familiar?
