» Insurance
BikeBanditATV.com - Write Your Review and Win!
Allstate
JardineProducts.comOPP Racing
SportbikeTrackGear
Old 10-13-2009, 06:46 PM   #1 (permalink)
MotorcycleFred's Avatar
I Ride: 2006 ZX14
Adjusting brake pedal after Buell peg install
After installing my Buell pegs a few weeks ago I quickly found that there wasn't enough adjustment in the brake adjustment rode to make the lever go far enough down. Well today I decided to make that fix......
I unscrewed the adjustment bolt in the end of the master cylinder all the way out. Then I removed the two allen head bolts from the master cylinder mount. This allows the rear master cylinder to be moved around. I then took my 4" grinder and ground off about 1/4" of the bolt, then filed the sharp edges smooth...then ran the locknut down over the ground area to make sure it would thread properly. I then installed everything in reverse order. Now I have enough adjustment to make the rear brake pedal where I want it to be....
The job took about 30 minutes start to finish and its nice to be able to use the rear brake without lifting my foot off of the peg....
Meat is murder.... Delicious flame broiled murder....
MotorcycleFred is offline   Reply With Quote
Old 10-13-2009, 07:59 PM   #2 (permalink)
Forum Leaders
Shifty1's Avatar
I Ride: 2005 ZX6R
-Poetry written in gasoline.
Old 10-26-2009, 11:15 PM   #3 (permalink)
I Ride: 2007 Kawasaki ZX 14
Thanks for the info Fred. I have the Buell pegs also and I could not get the brake lever low enough.. The adjuster bolt is too long and the end hits the bracket when you adjust the brake all the way down...
I have been meaning to saw the bolt off some and readjust mine but I really don't use the rear brake for much [unless I am in a parking lot or manuevering slow downhill through gravel etc.]
I do not like to use the rear brake while trail braking/ cornering because it can get you into trouble real fast.. Better to do like Kenny Roberts said and go in slower but come out fast! I added a gizmo called a T.C.B. that limits the rear brake lock up and simulates ASB brakes.. It basically has some sort of spring loaded valve that releases some of the brake pressure in a cycle to help you feel when the brakes are about to lock up.
Works pretty good for the ZX14 rear brake (which has a tendency to lock up the rear wheel too easily)
Keep the shiny side up and the rubber side down! <Speedy><
Speedy14 is offline   Reply With Quote
Old 11-01-2009, 09:45 AM   #4 (permalink)
I Ride: 2006 ZX14
I'll have to look into the TCB unit....
I trail brake....always have....been doing it for 100,000 miles or so and haven't had any problems so far, but then again I'm real careful when doing it. My riding style is hard into the corners and very hard out of the corners and usually I carry way to much speed into them (and the ZX14 doesn't make it any easier to slow my corner entry)......
Old 11-03-2009, 05:37 AM   #5 (permalink)
I installed the Buell pegs last week. We went for a little "spirited" ride Sunday. They are not going to work for me. I touched the pegs down way too many times even with the feelers removed. I may try them on the Bandit.
'08 Midnight Blue ZX-14
'08 Black Suzuki Bandit
cjd223 is offline   Reply With Quote
Old 11-03-2009, 09:18 AM   #6 (permalink)
Forum Leaders
BULLDOG's Avatar
I Ride: ZX14-and for the dirt KLR 650, and for the dirty shit, a girl called Petra.
I've heard that the pegs hit the ground more easily?? is that true?
"People sleep peaceably in their beds at night only because rough men stand ready to do violence on their behalf."
BULLDOG is offline   Reply With Quote
Old 11-03-2009, 11:27 AM   #7 (permalink)
I Ride: 2006 ZX14
I consider myself to be a fairly good rider especially in the corners and I haven't had any problems so far. My boots touch down first but I'm used to that because I wear a 14 EEEE... I have no chicken strips on my tires and I haven't touched a peg yet......
Old 11-03-2009, 12:13 PM   #8 (permalink)
I Ride: 07 ZX14
Did you leave the peg feelers on or off?
BigEbusa is online now   Reply With Quote
Old 11-03-2009, 12:36 PM   #9 (permalink)
No feelers. My feet don't touch. I ride the twisties with the balls of my feet on the pegs. I do admit the curves where the pegs touched were pretty tight.
I am not one of the knee down riders - too old for that. I am more of a shoulder on the mirror type.
Harley Davidson Suzuki GSXR Ducati Forum Kawasaki Forum
V-Rod Forum GSXR Forum Ducati Monster Vulcan Forums
Harley Forum Suzuki SV Honda 600RR Kawasaki ZX Forum
Buell Forum Yamaha R1 Honda 1000RR Kawasaki ZX-10R
KTM Forum Yamaha R6 Honda Fury Forums Triumph Forum
Victory Forums YZF-R6 Forum Honda Goldwing Triumph 675
Can Am Spyder Aprilia Forum Sportbikes Forum BMW S1000RR Forum
