JazzMotorsports.comATV.com5150 ConceptsBikeBanditAdvanstarMotorcycleShowsSuperbikeToyStore.comMotorcycle.comMotorcycleToyStore
BikeBandit
Old 06-08-2008, 05:16 PM   #1 (permalink)
I Ride: 2008 ZX14
TRE on a 2008???
Just wondering if anybody out there has installed a TRE on an 08 yet. With the 08's secondary throttle's opening sooner I am wondering if this mod will result in any more noticable torque. Any thoughts?
AccelJunkie is offline   Reply With Quote
Old 06-09-2008, 04:44 PM   #2 (permalink)
I Ride: 07 CPB ZX-14
Just pull the flies if you're that worried about it. Not worth loosing your gear indicator, even if you get a TRE with a peel an paste gear indicator..........
Serving proudly, USAF - It's time to kick a$$ and chew bubble gum, and I'm all out of gum!
LOWFLYER is offline   Reply With Quote
Old 06-09-2008, 06:54 PM   #3 (permalink)
I Ride: 2008 ZX14
I have read that it's a waste to pull them on an 08 because of the revised computer opening them sooner. I was just wondering if a TRE would give it even more bottom end grunt?
Old 06-09-2008, 10:21 PM   #4 (permalink)
I may be wrong but pulling the flies without some type of maping is a bad idea?
Thought I read where it will have a huge lean spot...
man00 is offline   Reply With Quote
Old 06-10-2008, 07:51 AM   #5 (permalink)
ZuluNinja's Avatar
I Ride: '07 ZX-14, '86 Honda VFR 750 & '03 Nissan 350 Z
won't pulling the flies eliminate your gear indicator?
Captain of the Black Z's
ZuluNinja is offline   Reply With Quote
Old 06-10-2008, 08:11 AM   #6 (permalink)
mcmmotorsports's Avatar
I Ride: 2007 ZX-14
Nope.
www.mcmmotorsports.com
mcmmotorsports is offline   Reply With Quote
Old 06-10-2008, 08:44 AM   #7 (permalink)
Originally Posted by mcmmotorsports View Post
Nope.
. All a TRE does is trick your ECU into thinking it's always in 6th gear where if I understand correctly the flies are pretty much always full open. Only problem with that, especially with early TRE's is that your gear indicator on the gauge cluster will always read 6. I don't know about you guys, but I happen to like my gear indicator. Newer TRE's come with a gear indicator attached to the TRE with double sided tape so you can tape it to the gauge cluster.....no thank you....
Old 06-10-2008, 08:47 AM   #8 (permalink)
I Ride: 2007 ZX-14
That is soooo Ghetto.
Old 06-10-2008, 08:49 AM   #9 (permalink)
I couldn't agree more.....if you don't like the performance hindrance of the flies, just get rid of em.....
Old 06-11-2008, 09:28 PM   #10 (permalink)
I Ride: 2008 ZX14
So nobody with a 2008 has installed a TRE yet?
Old 06-11-2008, 10:26 PM   #11 (permalink)
I may be wrong but TRE2008 = HP loss of about 6HP
Old 06-12-2008, 08:11 AM   #12 (permalink)
So is there any need to pull the flies out on the 2008? Anyone compare the 06-07 to the 08 with the flies in?
scorpion1981 is offline   Reply With Quote
Old 06-12-2008, 09:24 AM   #13 (permalink)
From just about all I have read..I would say no no need to pull the flies.
