ATV.comAdvanstarMotorcycleShowsMotorcycle.comSuperbikeToyStore.comJazzMotorsports.comBikeBandit5150 ConceptsMotorcycleToyStore
Go Back   ZX Forums > Kawasaki Motorcycles > ZX-12R Forum
JazzMotorsports.com
Old 11-28-2007, 05:00 AM   #1 (permalink)
2001 ZX-12R PCIIIR Problem
I have a 2001 ZX-12r, I purchased a PCIIIr, when I recieved it, I loaded the map from the dynojet website for the muzzy pipe and stock air filter, which is all i have done to the bike. Plugged the pc in, then started the bike. The bike had absolutly no acceleration, and started running hot. So I unplugged the pc, and ran it on the stock ecu. The bike ran fine, then a few weeks later, I tried plugging the PC back in, and now the bike wont start at all. On either the pc or the stock ecu. I have checked forums about checking for codes, and there does not seem to be any codes on the bike. It has a constant short flash on the FI light. Can anyone help me?
anfletch02 is offline   Reply With Quote
Old 11-28-2007, 07:37 AM   #2 (permalink)
VOZ
Moderator
VOZ's Avatar
I Ride: WADDED 2002 ZX-12R
did you make sure not to pinch any wires?
Was it a new pc3r or used?
send it back to Dj they will fix and replace for free..
I had the same problem.. Sometimes it is better to go with a pc3 and get a muzzy advancer for timing..
Custom maps are the best way to get the most out of the pc3
VOZ is offline   Reply With Quote
Old 11-28-2007, 07:43 AM   #3 (permalink)
i bought it used, but i helped him take it off of his bike, and then put it on my bike 2 hours later (for the first time).
Old 11-28-2007, 11:34 AM   #4 (permalink)
VOZ
Moderator
VOZ's Avatar
pc3r is shot.. or a wire is pinched..
Old 11-28-2007, 05:58 PM   #5 (permalink)
well finally got it to fire, however, it is only running on two cylinders. this is on the stock ecu, not the pciiir. Hoping it is just the spark plugs, the bike has 45000, yes 45000 not 4500, miles on it. did get a fault code to appear too, it seems to be 51. does anyone know what that code is?
Old 12-04-2007, 09:20 AM   #6 (permalink)
VOZ
Moderator
VOZ's Avatar
You can try calling your local Kaw shop for code info
Old 09-06-2008, 05:40 PM   #7 (permalink)
i have a 2004 zx-12r im trying to get it to work with a pcIIIr for a 2002 zx-12 become i hear it the best to use. It also hook right in to my plug. Run for awhile then shut off. I put a 2002 map on the pc, run longer but cant rev
pacman112283 is offline   Reply With Quote
