Originally Posted by johnandchris
Hi folks.
I think that you are porbably right, incorrect refitting. I normally do them myself on the zzrs that i have had, however no centre stand on the 12, bugger!!!!
I will try and find the problem, any ideas how to raise the front without a dedicated centre stand?
ZZR LON, i seem to recognise your avatar fomr the zzr-international forum, were you a member on there?
Regards
john
yep guilty as charged
if you can remove the fork top first so it pops up and see if it works then as that may sort it .
put it back in different way and that may be all that's wrong
you can try this if it helps
i found if you put a jack under the right side of the engine you can lift the bike enough to get the fork leg out.(trolley jack with some wood between jack and engine)
use something to chock the rear wheel front and back or find a way to apply rear brake.
undo all the time consuming bits guard calipers etc
undo the wheel axle before you lift the bike then just lift it so the wheel is just clear.
the side stand works as a pivot.
you may have to remove the leg to do the job and a vice would help.
if this sound a bit scary it is but it works (just make sure your happy with the jack and that first.
the other option is abba stand or the garage roof for support and rope etc
