Give the slides a push with your finger. If they all move easy, and return the same speed on their own, they should be ok. I'd suspect that your diaphrams are not seated or dammaged, or something is blocking the hole in the slide. First suspect is the diaphrams tho. Sometimes they can be a beotch to get seated proper when they are old. I figured out the hard way that some carb cleaners will dammage them too, so I pull that stuff all out and only use carb cleaner to hose out the small passages and disolve goo in the bowls, with as much of the rubber parts out as possible. Once I got this sorted on my 9r they all reacted the same when pushing them with my finger and when running.
