Originally Posted by BlackFrost
let us know how that turns out...gonna re valve the forks on my 95 zx11d...good luck...
Make sure you have the tool on hand to loosen the allen bolt from the piston. I didn't, and had to take mine to a dealer to loosen; one leg loosened fine, the other, he said, was difficult. Both allen bolts had factory threadlocker on them, and they had never been off until now.
Once apart, I made a tool to tighten them [calls for 29 ft lbs torque]. The top of the piston [Kaw calls this "fork cylinder" - #44022] has a 12 pt socket configuration, so some sort of hex-head tool was needed to hold piston while tightening allen bolt. My tool inexpensive and easy to make: I took my piston and my dial calipers to Lowes and found a pipe fitting reducer bushing with a hex that almost fit into the piston hex - the bushing is a 3/4 X 1/4 reducer, and its hex measured 1.160" across flats - I needed 1.152", and a little dressing with a file made the perfect fit; next, I re-tapped the 1/4 NPT hole in the reducer to a 1/2-13, and screwed a 1/2" socket head cap screw into it, lock-tited it, with a jam nut on each side. Now I can reach down onto the fork tubes with a two foot extension [w/ a 3/8" allen socket] and hold the piston while tightening. The reducer bushing was a little over a buck, and the 1/2"shcs [2"long] I had on hand. My 3/8" drive extension is 24" long.
Hope this helps anyone contemplating disassembly of their forks [at least the C model].
Dick
